3-Point Hitch Help removing a King Kutter rotary cutter
/ Help removing a King Kutter rotary cutter
The salesman said the tractor we bought was too light for a front hay spear and I took him at his word.
/ Help removing a King Kutter rotary cutter #42
You moving round bales 650 to750 lbs front spear will work my kubota is about the same size I move large square bales 3x3x8 750 lbs....
/ Help removing a King Kutter rotary cutter #43
With the mower in the back, it should counter loader weight of a 4x5 round bale
/ Help removing a King Kutter rotary cutter #44
The rear carry will be a lot easier on the tractor, especially if the ground is rutted or rough.
/ Help removing a King Kutter rotary cutter #45
Donhite...I sit the front of the cutter on boards so you can move it side to side easily. Remove one side, slide the cutter, remove other side.
/ Help removing a King Kutter rotary cutter #46
Or better yet, carry one with a spear on the loader and one with a 3pt hitch bale spear :D
/ Help removing a King Kutter rotary cutter #47
Question, why would you buy a 3 point hay spear with a front end loader?
As far as the quick attach, I would not use it with a PHD.
You cannot use a 3pt. PHD with a 3pt. quick attach due to having to remove the top link in order to pin the PHD directly. Then the hoop is attached to the 3pt. arms.
/ Help removing a King Kutter rotary cutter #48
Bluesteel, I know you are right. I just didn't want anyone to think they could use a PHD with a quick connect. I am sure that there is someone out there that may think it or even try it.
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2020 John Deere 6120M (A62180)
2020 John Deere...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
YALE FORKLIFT (A63291)
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
