Help please - L2850 is dead!
   / Help please - L2850 is dead! #11
If applicable (L2850???), rock your hydrostatic pedal back and forth and allow it to find it's neutral spot. Move the pedal with your foot through the full range of motion and see if you can place the pedal in it's sweet spot (neutral).
Also tap the pedal to allow it to return to its safety switch's neutral position on it's own.
Thanks for all the good suggestions. I will try to check all of these out early this week.
FYI, I'm in Havana, Illinois, which is about half-way between Peoria and Springfield on the Illinois River.
Thanks again and keep it coming!
Josh
   / Help please - L2850 is dead! #13
Josh
I spent 13 winters in Bloomington, IL. I am back in my home state now. Better you than me. :D :D
You never did say what model is the L2850 for transmission reference. Gear or hydro?
   / Help please - L2850 is dead! #14
If it is indeed an L2850, then it was built about 1985-1990 and did
not have HST available. Clutch safety switch only. If it is really a
2003 model, then I think you meant L2800 and HST WAS available.
   / Help please - L2850 is dead! #15
Duckguy,
We've got an older L2850 at work that's had the ignition switch replaced a couple of times for reasons similar to yours. I'd start down by the starter and start tracing your hot lead from there to find where it dies at but it's possible that it is the switch. BTW I'm just north of you up here in Galesburg!!!!
   / Help please - L2850 is dead! #16
We recently painted our work tractor NH 1520 took it all apart fenders seat tires and wheels. Just me and the guy working with me. Painted it and re assembled it. Went to start it ....nothing.... Now im not the best mechanic but am fairly knowledgeable. Called the dealer for ideas, so I did as my uncle says if you cant figure it out sit back and look at it. Well as it was the MMM lever got engaged as we were painting it, never even thought about that because we NEVER use it. So what Im saying is sit back and look at it . V
   / Help please - L2850 is dead! #17
Thanks guys for all the suggestions. I hope to get back to taking a look at it on Thursday. According to what's painted on the tractor it's an L2850, but I must have the year way off. Maybe they bought it used and that was the year they purchased it. All I can find is the clutch switch!
And I will just take a look a it and see what's up. Thanks for all the advice!!!
Josh
   / Help please - L2850 is dead! #19
My first tractor was the 3cyl version of the L2850, called the L2550. That
is why I know it had only that one safety switch. My starter switch failed
on that tractor and I started it with a short piece of wire to short the
battery connection to the hot solenoid terminal until the new starter
switch arrived in the mail. That was the easiest starting tractor I have
ever started. Mine was an 89, I believe. Many Kubota tractors have a
date stamped on the wheels, if you want to check that for vintage. It
may be 20y old, but that does not mean it is not a great tractor. I tried to
fix my starter switch, but it was beyond hope.
Well, I was way off! It's a 1985 or 1986 it appears. I feel stupid.
Anyway, the plot thickens a bit. Someone was looking at it yesterday, but wasn't able to figure anything out. I had found the wiring diagram in our documents file, so I looked it over and went out to take a look. The guy yesterday left the hazard lights switch on, and when I walked in they were flashing! I shut it on and off and they continued to work, but no headlights. I turned on the key and the dash lights lit up. I hit the key, and everything stopped working and once again nothing works.
Looking at this diagram, I wonder if it's not this "combination switch". Pardon my stupidity, but could it cause this problem? Besides controlling all the lights, it appears to have 2 ignition wires running into/out of it. I had assumed it would have nothing to do with starting the tractor, but now I'm wondering.
I'm also checking out the fusible link, just haven't gotten to it yet.
Finally, can anyone tell me what the "timer relay" is and if it's the type of part that could cause such a failure.
I take back whatever I said about being a reasonable mechanic. This is way out of my league and I appreciate everyone's help and suggestions.
Josh
2003 STERLING ACTERRA FLATBED DUMP (A51222)
2003 STERLING...
2014 Dodge 5500 4X4 Bucket Truck (A52128)
2014 Dodge 5500...
2013 Infiniti JX35 SUV (A50324)
2013 Infiniti JX35...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
