Help please - L2850 is dead!
/ Help please - L2850 is dead! #21
DUCK,
Both the starter switch and headlight combo switch are subject to
water and dirt entry. If I recall, you can not turn on the headlights
unless the starter switch is on. That is why the combo switch has a
connection to the starter switch.
Replace at least your starter switch (about $60). Then you will also have
the ability to use the glow plug position (counter clockwise from OFF).
Oh yeah, don't let water get into the new switch(es). Good Luck.
/ Help please - L2850 is dead! #22
Duckguy said:
I hit the key, and everything stopped working and once again nothing works.
This sounds like a bad connection from the battery. You said that you changed the negative cable so that connection should be tight. I would check the positive cable where it bolts to the starter and make sure the connection is clean/good.
Vic
TRANSTORE 2000 GAL STORAGE TANK (A67714)
TRANSTORE 2000 GAL...
BOOM FOR HYDROVAC TRUCK (A68842)
BOOM FOR HYDROVAC...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
PALLET OF 2CYL GAS ENGINE/RADIATORS AN PARTS (A68842)
PALLET OF 2CYL GAS...
CENTRAL PNEUMATUC 9 GALLON GAS AIR COMPRESSOR (A67714)
CENTRAL PNEUMATUC...
