Help! Need ideas to build the "ultimate" workbench
   / Help! Need ideas to build the "ultimate" workbench #41
Re: Help! Need ideas to build the \"ultimate\" workbench
A couple years ago I was looking through old threads on heavy duty work benches and there was a picture or series of pictures of what I thought was the heftiest work bench I've ever seen. The guy built it out of plate steel or something. It looked like you could park a dump truck on it. If anyone knows where those pictures are they deserve a second posting.
Update:
Found it here: http://www.tractorbynet.com/forums/...7063417-lets-see-your-workbench-workbench-jpg
Tough to beat steel I-beams for sturdy support. I know there are nicer / more fancy benches out there but for some reason I just think this one is awesome.
   / Help! Need ideas to build the "ultimate" workbench #42
Update:
This is far from being an "ultimate " work bench but it IS sturdy.
I built this one last year. 3inch thick steel top. Two 20" deep I-beams for the pedestal legs. Total weight just under 2000 #.
Terry
   / Help! Need ideas to build the "ultimate" workbench #43
I bet it is! At least it looks like the corners are rounded or you would leave pieces of yourself on it as you passed by...
   / Help! Need ideas to build the "ultimate" workbench #44
Re: Help! Need ideas to build the "ultimate" workbench
I don't care if it is wood or metal, I just want a clutter-proof top!
Bruce
   / Help! Need ideas to build the "ultimate" workbench #45
Terry
You have the best shop I have seen yet and cleeean!
   / Help! Need ideas to build the "ultimate" workbench #46
Thanks! :)
   / Help! Need ideas to build the "ultimate" workbench #47
A timer control that folds it flat against the wall; every night at 3AM
   / Help! Need ideas to build the "ultimate" workbench #48
One that I use a lot is a platform that I use on my small walkie forklift. It is great because you can easily change the height of the bench. You can lower it to the floor to easily get heavy items on the workbench. I use it more than I use my traditional workbench.
   / Help! Need ideas to build the "ultimate" workbench #49
pretty much all my tables and benches have three quarter plywood on top and cover with "monsta liner" bed liner. Of all the roll on bed liners ive used Monsta liner is the cats meow. If that boo boo ever happens it readily fixable repairable. very durable stuff. I do have one table laminated in 20 gauge steel that i weld on though. Bed liner dont like heat.
Filing cabinets make dandy "under the top" drawers for more bulky items.
   / Help! Need ideas to build the "ultimate" workbench #50
Mine is wood with a metal top. Yes, I like pegboard, and have air plumbed to the bench. Just home gamer, so plenty sturdy. It's 12'x30" and framed with 2x4 wood and 4x4 for the legs. I split a 1/4 sheet of mild steel and built in a bottom shelf too. Not the best pics since I painted everything black, but give you an idea.
I like pegboard for go to tools, but keep everything else organized here
Here is a pic to show a bit of scale. That box is 6', and the bench is 12'. Many say build a smaller bench so it doesn't get junked up- I'm the opposite. I like it big because, well, the extra space is nice if you have the room. That wall is 30', and with a beverage fridge and man door, the space gets used up fast!
Cheers
Adams 5T Pull-Type Fertilizer Spreader (A56436)
Adams 5T Pull-Type...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
