Help Me Find A Pulley
   / Help Me Find A Pulley #31
I am trying to convert an old makita that I don't use anymore into a debarking tool. The kit I bought comes with pulleys for Stihl and Husky. I was hoping one of them would work with the Makita, Doesn't seem like they will. So I need to find a pulley that will work. I figure if I use my digital caliper to find the diameter of the post on the makita I can find something that will work. I am here to ask if anyone know a source for such a thing. If does not have to be very elaborate. The included pulleys are quite simple. Once has a bearing in it the other does not. Suggetions? Tips? Warnings? HELP!View attachment 2410331
I believe the Makita saws are made by Dolmar. You might try their parts system.
   / Help Me Find A Pulley #32
Would it not be simpler to return the one you purchased and get one compatible with your makita? Also I saw on Amazon, a chain driven model that was like $70 where you only have to get a chain that is 2 inches longer than yours.
Looking for that special pulley might take you a long time...
   / Help Me Find A Pulley #33
Makita and Dolmar made cut off saws that use a V belt to drive the cutting disc. You might be able to find one of those pulleys online. Many of those saws had little maintenence and died early, but the pulley would be reuseable. but note those pulleys are clutch driven. Maybe you can pick up a used saw on marketplace or E bay.
I have found one that is Makita specific, but I have not found a source for it here in the states. I will keep looking for that, they are bound to be here. If I can't find the one O need I might have to go the log wizard route, but I want to find a chain without teeth. That seems extra scetchy. They make those right?
Great idea.
   / Help Me Find A Pulley #35
Look at the old clutch *drum* (agreed, bad nomenclature in those instructions) and see what the measurements you need are. Reinstall that old clutch drum and set a straight edge alongside the drum extending out to the debarker pulley. Check the offset you need to the pulley groove that way. It's a rubber belt, it doesn't need to be within a few thousandths of an inch. 1/32" will do fine. Likely even 1/16" won't *kill* you. Look to the old clutch drum for your bearing and ID requirements also.
   / Help Me Find A Pulley #36
If you can figure out what you need and what pulley you are going to use i can bore out the pulley or make bore one out to fit with a sleeve pressed in
Just take a well used chain and grind it down will probable be easier.
Well none of my chains are long enough, so I have to buy a new one anyways. I looked, the toothless chains are only $15-$25 depending on size.
   / Help Me Find A Pulley #39
Could you keep the stock clutch and sprocket, and convert the cutting head to chain sprocket? You could then fit a chain with the cutting teeth ground off, or perhaps just buy a toothless drive chain.
The Forest Service had some experimental units which were supposed to get you down to bare mineral soil, by flinging the covering organic soils all over the poor fool running it. They had a chain sprocket on the flinging head.
   / Help Me Find A Pulley #40
From one Pulley to another (last name is Pulley... :) ), anyway, looks like you could simply measure the OD of the Shaft, measure the ID of the pulley without the bearing. Find a needle bearing, press that into the pulley. If the pulley with the bearing in it has the same ID (excluding the bearing) you would have two or if it is indeed different that gives you more options for available sizes. There appear to be only three measurements that matter, OD, ID and length of the bearing.
Use a bearing press push in the new one. Looks like a fairly simple job to me, provided you have a press. If not put the pulley on two blocks and using a block of wood on the new bearing tap into place. Seat to about the same depth as the one pictured with the bearing in it.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A56860)
2025 Kivel 48in...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
John Deere 950 Tractor (A57453)
John Deere 950...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
