help id this pin
/ help id this pin #1
jiminpa
northwest pa
massy 35 diesel kubota l3400
i think its a bush hog mower. was my ex's grandfathers, completely rebuilt by him. this pin came out of the quick disconnect on the pto shaft.
/ help id this pin #2
It appears to be the pin you depress to allow the PTO shaft to slide into place and hold it in place once properly situated.
/ help id this pin #3
I think you've already identified it. The ones I'm familiar with use a spring for tension and clip to keep it in the hole.
/ help id this pin #5
Lost mine one time.
My solution was to clamp a 3/8 bolt in my drill press and using a file I 'turned' one (LOL, vertical lathe).
Drilled a hole for a cotter pin and scrounged a suitable spring.
That was 8-10 years ago and still holding just fine.
Not the most economical but sure saved lots of time plus I like DIY.
/ help id this pin
got the pin showed above. had to do a little fitting, but got it on. now if it would quit raining i can try it out!
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
2017 Mack Semi (A64047)
2017 Mack Semi...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
