HELP............ECHO CS341
/ HELP............ECHO CS341 #1
lomita
El Dorado Hills
Kubota L48
My ...ECHO CS341 runs erratically and won't stay running when I release the trigger.
Here's the kicker, if I turn the saw from a vertical position to a horizontal position (90 degrees) it runs great!
I think there is a leak in one of the fuel lines..........what are your thoughts?
/ HELP............ECHO CS341 #2
Quick, easy checks- gas cap breather is clogged. Carb is flooding (adjust carb) , carb leans out when turned.
Is the fuel tank filled or partial?
/ HELP............ECHO CS341 #3
When did you last replace the fuel filter? Sometimes they're in the tank.
It does run better with a full tank. Fuel filter has never been replaced but has been cleaned. Gas cap doesn't have a breather hole that I could find.
Thanks to all for the replies...........I'll keep you posted.
Steve A.
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
24in pin on excavator tooth bucket (A61307)
24in pin on...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
