HELP............ECHO CS341
/ HELP............ECHO CS341 #1
lomita
El Dorado Hills
Kubota L48
My ...ECHO CS341 runs erratically and won't stay running when I release the trigger.
Here's the kicker, if I turn the saw from a vertical position to a horizontal position (90 degrees) it runs great!
I think there is a leak in one of the fuel lines..........what are your thoughts?
/ HELP............ECHO CS341 #2
Quick, easy checks- gas cap breather is clogged. Carb is flooding (adjust carb) , carb leans out when turned.
Is the fuel tank filled or partial?
/ HELP............ECHO CS341 #3
When did you last replace the fuel filter? Sometimes they're in the tank.
It does run better with a full tank. Fuel filter has never been replaced but has been cleaned. Gas cap doesn't have a breather hole that I could find.
Thanks to all for the replies...........I'll keep you posted.
Steve A.
CAT 272D3 SKID STEER (A65053)
CAT 272D3 SKID...
Takeuchi TB225 (A62177)
Takeuchi TB225...
Caterpillar 299D3 (A64126)
Caterpillar 299D3...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2016 Ford Explorer SUV (A61574)
2016 Ford Explorer...
