Grapple heavier grapple or not
   / heavier grapple or not #21
I'd buy the very same size grapple again. Many of the same players...same views....with most going for the 48" size grapple. :thumbsup: (I think the same arguments are made over and over :laughing:)
That would be a good decision for a guy like you that doesn't use it..:D
hey guys thanks...i didn't mean to start a debate... i'll search previous threads and send pics after purchase.
   / heavier grapple or not #23
we love grapple arguements. you're only on post # 7, just wait till you ask about tires..
   / heavier grapple or not #24
Or hydro vs gear transmissions. That is always good for about 10 pages of posts.:laughing:
I have a Anbo Grapple rake and it is a 66" wide. Sometimes I like the width and sometimes I dont. The narrow grapple will allow you to focus the forces on a smaller area. Your machine is bigger and heavier and would have a good bit more power that the CUT size tractor most of us have.
   / heavier grapple or not #25
You just bring those matchbox toys of yours around and try to keep up with me sometime.....sonny. :D:laughing:
   / heavier grapple or not #26
Looking up old threads is really the best way to get information here. By the time you get done reading, you'll really have a good idea of what you need for your job.
   / heavier grapple or not #27
Bought a Gator light duty (after reading the various opinions) and have found it to be a good fit for my loader and tractor. I am reasonably well balasted (Rimguard in rear tires and boxblade on rear) and have been able to move rocks that make the back end very light... Been a great tool for woods clearing and rock removal.
BTW I started what I though was a simple thread on diesel additives a while back this is still going strong...little did i know there was that much passion around that subject!
   / heavier grapple or not #28
There really is a lot already written about this issue.
The Kubota M series is pretty heavy and so I'd want to know how the user intended to use the grapple before making a recommendation. If it is just to pick up debris laying around or lifting felled trees then the basic light duty Markham/Gator etc would do fine IMO. If on the other hand the grapple will be used to root rake or dig out trees then I'd opt for the heavier duty steel in the 48 inch version to give it more rigidity as the momentum with a M would be quite a bit and striking an unseen stump or immovable rock/object assymmetrically would put quite a bit of twist on the grapple.
I know Jake and others are happy with their wider heavier grapples but I've still in five years never seen anyone with a bigger grapple post a photo or describe something they were able to do that our little bitty 48 inch grapples cannot do just as well. The concerns about hitting an unseen object with the edge of the grapple are multiplied when using a grapple that is wider than the FEL arms too. The notion that you cannot drive into brush with a narrow 48 inch grapple are bogus. I do it all the time and come out with huge loads.
Here is my latest capture with my 48 inch Millonzi (weight 280lbs). I could only lift the stump this high and as my loader is rated for 2700lbs to full height at pivot pins, I'm guessing this stump weighed something close to 3000lbs. If my grapple weighed 500+lbs, I probably would not have been able to lift it and move it.
   / heavier grapple or not #29
there he goes.. showing off again.. ;-)
wait till I post a pic of a load of firewood all stacked on mine.
   / heavier grapple or not #30
The advantage in the Gator is that there are almost none in that small size/weight (48" & ~400 lbs), so if you need small they are about the only game in town at the moment. There are disadvantages to dealing with Gator which include some questions on recent quality and responsiveness. In my case, my new gator grapple popped off my quick attach in use. It came down to loose tolerances on the QA mounts on the grapple (my tractor's QA has no problem holding onto other attachments). They eventually sort of fixed it (sent parts, I welded them on) but I was not terribly pleased with the whole experience. Since then it has performed well. This is all over the past 2-3 months.
You have a much bigger tractor than most folks posting on this thread. MUCH bigger. It is capable of handling most regular skid steer size grapples. Something 60-66" should be easy to find, and from a number of suppliers ranging from cheap to high-end. As long as you don't go too crazy on the weight you should be in a very good position. Perhaps check with local dealers and you can find something nearby. And without the recent Gator drama or shipping hassles. That would be where I would look in your shoes. My $0.02...
-Dave
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
6' PULVERIZER, 3PT (A52708)
6' PULVERIZER, 3PT...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2015 Ford E-350 Cutaway Box Truck (A55973)
2015 Ford E-350...
