Heating my shop?
/ Heating my shop? #21
Gary - OK, I left myself wide open. I'm usually the one making comments like that /forums/images/graemlins/grin.gif
/ Heating my shop? #22
If building new and are thinking about heating all the time
put radiant tubes under concrete and use an outside wood
fired heater or a hot water heater and pump to keep it warm.
I have radiant under basement and attached 26x28' garage.
I use a wood fired heater to supply the hot water for this,
forced air in house and heat the 40x60x15' shop.
My drywallers complained about house garage was 78* and
below 0 outside /forums/images/graemlins/grin.gif,had to cut the water back.
/ Heating my shop? #23
David-My pole barn is 30x44 with 14' side walls. Originally there was no interior walls, ceiling, or insulation. I heated with a 110,000 torpedo heater but all the heat went to the rafters. I now have interior side walls, ceiling, and insulation in the ceiling and walls. The torpedo heater now heats the building nicely. A retired friend just finished hanging a 40' Rayvac radiant propane tube heater. Will fire up as soon as the propane tank arrives in a week or so.. We have 4 radiant heaters at our truck service shop and it works much better than the old forced air we had. I would want at least a 30' heater in a 40' building. You can buy a 40'er and cut off a couple foot. The burner end puts out a lot of heat but gets less as the heat goes down the tube.
/ Heating my shop? #24
The building is already up. I don't plan on heating full time - just when I'm working on something and maybe enough to keep things from freezing. Otherwise I most definitely would have gone with radiant. I have 4,500 sq.ft. of it in the house - its nice to walk barefoot on the slate floors.
/ Heating my shop? #25
BobinCols,
Thanks for the information. How may BTU's is your new heater?
This question started because I found a 20' Reznor heater on EBay for a nice price. I asked the seller about 30' and he can also provide one at a reasonable price. I guess I need to think about cutting a 40' one down. I'll be spending most of my time on one end of the building so I'll put the burner end over the primary work area.
/ Heating my shop? #26
David-The 40' is 125,000 BTU's and the 30' was either 100 or 110,000 BTU's. The 30 probably would have done fine. The 40' was around $150 more so I bought it. Haven't paid for the 40' heater yet but it should be around $1000 wholesale plus the installation. I will heat the shop only when I will use it. BOB
207280 (A52708)
207280 (A52708)
2014 Jarraff Geo-Boy Mulcher (A64047)
2014 Jarraff...
(2) ROW PLANTER (A62130)
(2) ROW PLANTER...
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
Kubota M125X (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
