Headlight Grill help needed
/ Headlight Grill help needed #1
Scotty Dive
Ct
Yanmar 2020D
Looking for some ideas. My stock headlight grill is breaking itself apart. Has a few cracks in it and from the hood shaking when the engine running its starting to self destruct. So I made some calls and called Fredericks who told me that the version they had was a reproduction version made from steel instead of plastic like the original and that I would need to do some slight grinding to reattach the existing lights. Perfect I said. In my discussion with Fredricks they mentioned this is the same one Hoye sells. Even more perfect because I had to place an order with Hoye so I added it to the order. What I got was plastic and the lights will definitely not fit in the holes. Which is clear as day as a note on the Hoye website.
So, I am thinking...I return the one to Hoye and order the steel one from Fredricks - So I call Fredricks and they said whooppps, we made a mistake, we only carry they plastic one (same as what I got from Hoye). So now I have a $70 grill and need to order another $90 in lights that will fit.
Now, I like the tractor to be complete and try to fix things as they come up, but having to spend $160+ on a grill and lights that I hardly ever use and really don't provide much light especially with a loader installed is just crazy in my opinion.
So, enough of my ramblings.....I need a used one or if anyone has any wild ideas that would work please let me know. I would not mind upgrading the lights to LED's to get more usable light, but as far as I can see no one makes a replacement LED bulb.
Btw, I called around for a used one; Jamiesons (left a message), Fredricks, Mid South Salvage, and West Kentucky, and Schaeffers all with no luck. Any ideas guys?
/ Headlight Grill help needed #2
Thanks Carey, but unfortunately that is the lower grill and doesn't look like mine at all :(
/ Headlight Grill help needed #4
I made one out of wood for my 2002D, probably not for most folks, but cheap.
/ Headlight Grill help needed #5
I don't know what yours looks like.But, I busted mine a couple yrs back and ordered the plastic upper grill, and had no problems with it working with the stock head lights
/ Headlight Grill help needed #6
If anyone ever finds replacement grilles for YM186D, both styles, I'm interested. Photo.
Hmmm. Winston I like your solution. I may try that! :thumbsup:
/ Headlight Grill help needed #7
ok , while it appears my 3110 shares the same lower grill,, the headlight grill appears to be different
/ Headlight Grill help needed #8
I have bought lots of Yanmar Tractor parts from them. Excellent to deal with, fair prices. Always found everything I needed and more. Very helpful folks.
Hoye Tractor
Yanmar Tractor Parts - Shop Online
2009 International Pro Star (A60462)
2009 International...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
2011 Caterpillar CB34 (A60462)
2011 Caterpillar...
