Headlight Grill help needed
/ Headlight Grill help needed #1
Scotty Dive
Ct
Yanmar 2020D
Looking for some ideas. My stock headlight grill is breaking itself apart. Has a few cracks in it and from the hood shaking when the engine running its starting to self destruct. So I made some calls and called Fredericks who told me that the version they had was a reproduction version made from steel instead of plastic like the original and that I would need to do some slight grinding to reattach the existing lights. Perfect I said. In my discussion with Fredricks they mentioned this is the same one Hoye sells. Even more perfect because I had to place an order with Hoye so I added it to the order. What I got was plastic and the lights will definitely not fit in the holes. Which is clear as day as a note on the Hoye website.
So, I am thinking...I return the one to Hoye and order the steel one from Fredricks - So I call Fredricks and they said whooppps, we made a mistake, we only carry they plastic one (same as what I got from Hoye). So now I have a $70 grill and need to order another $90 in lights that will fit.
Now, I like the tractor to be complete and try to fix things as they come up, but having to spend $160+ on a grill and lights that I hardly ever use and really don't provide much light especially with a loader installed is just crazy in my opinion.
So, enough of my ramblings.....I need a used one or if anyone has any wild ideas that would work please let me know. I would not mind upgrading the lights to LED's to get more usable light, but as far as I can see no one makes a replacement LED bulb.
Btw, I called around for a used one; Jamiesons (left a message), Fredricks, Mid South Salvage, and West Kentucky, and Schaeffers all with no luck. Any ideas guys?
/ Headlight Grill help needed #2
Thanks Carey, but unfortunately that is the lower grill and doesn't look like mine at all :(
/ Headlight Grill help needed #4
I made one out of wood for my 2002D, probably not for most folks, but cheap.
/ Headlight Grill help needed #5
I don't know what yours looks like.But, I busted mine a couple yrs back and ordered the plastic upper grill, and had no problems with it working with the stock head lights
/ Headlight Grill help needed #6
If anyone ever finds replacement grilles for YM186D, both styles, I'm interested. Photo.
Hmmm. Winston I like your solution. I may try that! :thumbsup:
/ Headlight Grill help needed #7
ok , while it appears my 3110 shares the same lower grill,, the headlight grill appears to be different
/ Headlight Grill help needed #8
I have bought lots of Yanmar Tractor parts from them. Excellent to deal with, fair prices. Always found everything I needed and more. Very helpful folks.
Hoye Tractor
Yanmar Tractor Parts - Shop Online
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2019 JCB 457 (A60462)
