hay wagon floor build
/ hay wagon floor build #1
chrisdvorak
RI
too many
/ hay wagon floor build #2
2 -4 x 4 beams 8 ft long with 2 x 6 or 2 x8 4 ft long running across. Then put a 1 x4 down each side. Ken Sweet
that seems very simple to make, but would it be strong enough on the ends of the 2x6's?
the only reason that I questioned the strength is because I saw these pictures from another thread that looks a lot more complicated, and didn't know if there were any big advantages to that slightly more complicated design.
/ hay wagon floor build #8
We used to build them that way about 15-20 years ago. Personal preference, I guess? Ken Sweet
/ hay wagon floor build #9
That is the same running gear that I bought years ago. I used a 9 foot long 2X6 for the runners on mine, then laid 54 inch 2X4 stretchers across them and 5/4 decking for a floor.
I've seen the floor boards laid vertical and horizontal, is it only personal preference or is one way stronger than the other?
how did you anchor the 2x6's to the frame?
/ hay wagon floor build #12
There was a tab standing up with a hole drilled in it, welded to each corner just a few inches away from each tire. I had to use a 2X6 on edge to get enough height for the floor to clear the tires.
Your question about which way to run the floor boards, I guess it would be mostly personal preference with this size of wagon. I ran mine front to back but most of the hayracks I remember as a kid the floor ran side to side. They let more of the hay chaff fall through the cracks making the floor not as slick to walk on.
/ hay wagon floor build #13
Just don't do what one of my Uncles did. Nice new wagon bed and 2 coats of white enamel. Like trying to stack hay on ice skates. Took several seasons to wear it down enough to get a toe hold.
/ hay wagon floor build #14
If I was going to paint a wagon floor, I would mix white sand in the paint. Ken Sweet
/ hay wagon floor build #15
We build our wagons only attaching two corners diagonal from each other. For example the right front and left rear. This allows them to flex more in ditches and ruts without snapping. I have also seen wagons roped, chained or cabled loosely the the corners that aren't attached. Good luck
-hwstem
155 (A64278)
155 (A64278)
Sioux Mineral Feeders (A66408)
Sioux Mineral...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
JOHN DEERE 7410 TRACTOR (A64278)
JOHN DEERE 7410...
John Deere L110 Riding Mower (A66408)
John Deere L110...
