Hay feeder for large stock
   / Hay feeder for large stock #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
See Attached
Material List for 2 Bins,
Qty. 4; 2 x 6-12 PT
Qty. 1; 2 x 4-8 PT
Qty. 2; 1 x 4-PT
Qty. 2; 1 x 3-16 Strapping
  • Hay Feeder Bin_Dims.PDF
   / Hay feeder for large stock #2
how do you plan on cleaning it out underneath / moving it. once old hay and poo starts covering the bottom portion? i would think it would be to heavy to muscle it around. and no easy place to run a set of forks on 3pt hitch. maybe a set of forks on FEL (front end loader).
   / Hay feeder for large stock #3
Like mentioned above the box section on bottom is going to fill up. I could see adding a 4x4 under it on both sides(cut at angle add piece pipe for pulling on) for skids where it could be moved easily and not have to be picked up.
   / Hay feeder for large stock #4
In days gone by many built there feed bunks out of wood, and most now days buy a steel bunk with a plastic liner, most of our old feed bunks were gone in a few years, and had to be disposed of.
some of the pressure treated lumber may not be the best for livestock, my even be hazardous to them,
there are a few listed here on this page, https://www.google.com/search?q=Goa...ChMIwdDY3KGnxwIVEEGSCh1fmgEx&biw=1024&bih=658
Good Idea about making provisions for forks on the bottom. I have a little Mahindra Max28 that I can get in the cow camp to muck it out and move the feeder, etc.
Our cows like to play with stuff, so I want it heavy. I was considering filling the base with Gravel. Our biggest steer I caught pushing our RTV900 just for fun.
The base will not contain grain, as we mter the feed and feed daily in a rubber bucket.
Regarding PT lumber. Copper arsenic is no longer used. It is some Vinegar based compound in the stuff they use in play grounds. Not as good as the deadly insect treatment, but reasonably safe, especially if you have PT that is aged at least a few months.
Note the stats are pine strapping, the base and legs are PT.
   / Hay feeder for large stock #6
lag bolts i assume for full putting stuff together? no screws / nails i would assume?
   / Hay feeder for large stock #7
I do not know what is available in your area, but a number of years ago a guy came through and turned tires inside out for feeders, I used one for a stock tank and bought a large construction tire for a second stock tank but some took the larger tractor tires turned inside out and used for feeders, they will take many many years to rot out, usaly the top side wall is cut off, then build a rack above that,
https://www.google.com/search?q=ins...X&ved=0CB4QsARqFQoTCKu7oNrdqMcCFc2ViAodLaYGcQ
one guys way of turning the tires,
https://www.farmshow.com/a_download_page.php?aid=MTM4ODM=
Wife wants it on legs and a roof on it now.
"So I was thinking combine the design of these two things, possibly using pallets? The idea is to keep it off the ground, but also give the hay air to breathe, and keep it covered so that the sun/wind/rain doesn't bleach it/blow it away/turn it sour.
If you make one for us, I'll bet the neighbors will want one. I already know Diane wants one."
http://www.barnworld.com/cattle-guards/Horse-hay-feeder-from-poly-panels/
Covered Hay Feeders
   / Hay feeder for large stock #9
cows are stupid...*ughs* remember having a few cows some how managing getting there heads stuck inside of a hay feeder built out of pipe. and remember my dad and other main farmer here clear back then. holding cow head up and sawing out pipes to get cow head freed, from the feeder. i remember moaning and groaning wishing the pipes for some of the feeders were bolted on vs welded on.
and for what ever reason.... they do not care were they pee / poo.... i think they intentionally at times back up, to the feed bunk to relieve themselves! *shakes head*
cows will rub up on anything if they got the itch. and they will kick stuff (assuming a bug bite / startling)
have seen cows push feeder rings for large round bails around. to point once large round bail gets down to the very center. cows will just push ring across hay that has fallen out of there mouths. and over to the center. basically only making 1/2 maybe 2/3rds of round bale eatable. everything else ended up on ground and mashed into mud / poo / pee.
   / Hay feeder for large stock #10
2 X and 1 X pine lumber for cattle? Maybe for sheep or goats. I don't think it would last a day if you have several steers or cows that are very active. Heavy oak would be better.BHD mentioned tractor tires, that would be a better alternative if you don't want steel. The new treated lumber twists much more that the old CCA treatment, especially if it will be in the sun.
   / Hay feeder for large stock #11
I built this one for 4x5 round bales after going thru several of the round ring type, which either the cows destroyed, or I did trying to move the cheap pieces of junk.
6x6 oak posts mortised into 6x6 locust runners with a steel "T" plate lag screwed at the joining point. Rest of it is 2x oak. 1.5" square tubing makes up the back (fixed) and the front (hinged to load). Roof keeps the bale dry. They don't waste near as much as the old round rings.
ry%3D480
Re: Hay feeder for large stock, What I built. (Photo's)
2 done two more to go.
$35.00 ea. in material.
The last two should take about 2-1/2 hours to build each. I'm going to rim the top with 1x3 pine straping so the horses do not nibble on the PT lumber.
Wonder how they will work with the cows?
   / Hay feeder for large stock #13
I don't think they will last long with cows,just my opinion.
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
WOLVERINE PT-16-01C 3PT HITCH ADAPTER (A60432)
WOLVERINE...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
UNUSED FUTURE BC63-57" HYD BRUSH CUTTER (A60432)
UNUSED FUTURE...
2009 Honda Civic Sedan (A59231)
2009 Honda Civic...
