Hay Customers?
   / Hay Customers? #11
I baled some Jiggs two weeks ago. Cut it Friday evening and baled it Sunday evening. It was cow hay for my cows so perfect was not a requirement, just dry enough to not mold and not so dry that all the leaves don't fall off. I would guess you need at least 3 days.
Another dryness method is to grab a hand full out of the windrow with both hands. Twist the hay like your peddling a bicycle with your hands 3 times. If almost everything breaks into two handfuls, its ready to bale. Jiggs seems to have more stems than coastal and some of the stems may not break.
One trick with moisture content. If its too dry in the evening, bale it the next morning when there is has a little dew on it.
   / Hay Customers? #12
Making hay is an art.
The moisture in the ground, the moisture in the air, whether it's cloudy or sunny, the wind, the lay of the land, the type of equipment used, equipment settings, and the species/maturity of the grasses all have a bearing on when it is "ready to go".
Sometimes you bale in the morning when the dew just comes off, sometimes in the evening as the air cools and gets more humid. Sometimes in the dark, and on and on.
After a while you just get to know. Your nose is the most important sense required. Smell it as you are feeling it, bending it, breaking it. Check the heavy swath and the light swath. Get to know your fields and your grass.
Commit to memory what proper hay feels like in your hands and most importantly; smells like. Moisture meters are a somewhat crude way of compensating for a haymaker's lack of "feel" when making hay. Or sometimes when conditions are tricky the meter gives you one more piece of info to confirm your own senses.
It can be difficult to make perfect hay, especially when the weather is not cooperating.
Bottom line; it has to keep.
Anyway, good luck!
   / Hay Customers? #13
Hayboy83
The few times I baled Coastal Bermuda at 20% moisture as indicated by my Delmhorst moisture tester it turned out musty/dusty. I try to stay around 15-16% moisture content for my hay.
   / Hay Customers?
Thanks for y'alls input. Holycow, I like the handle by the way, you make a lot of good points on getting to know your land and how perfection comes with experience. I'm just getting started with this type of grass so hopefully I can master it soon.
@Jim- what model delmhorst do you own? Joeu235-which moisture meter are y'all running? I'm pretty excited about this next cut. We haven't baled square bales since I was a youngin.
   / Hay Customers? #15
I don't own a moisture meter. I have played with a couple. I have no need of one. Not even a little bit. Ymmv.
Your nose and your hands, the air around you and the ground under you tells ALL of the story. The moisture meter tells you the moisture content of your sample, that is all.
The hay's condition frequently changes minute by minute...
   / Hay Customers? #16
May I ask how long have you been baling hay and approximately how many bales you have baled?
   / Hay Customers? #17
After a while you just get to know. Your nose is the most important sense required. Smell it as you are feeling it, bending it, breaking it. Check the heavy swath and the light swath.Get to know your fields and your grass.
Anyway, good luck!
I'll second this. I have baled hay for 15 years and I can tell when hay is ready by smell. I feed my own 40 horses and I don't like dealing with horse people. These are not backyard mutts either, well some of them are but the majority are show horses. Horse people think they know hay but its only what they have heard in conversation for the most part. I have never used a moisture meter and don't plan on getting one. I have let fields go that hay got rained on after the hay was dried for 2 days. Just take the hit, and spread it out with the brushhog. Its not worth baling.
   / Hay Customers? #18
I've seen balers with a spray system on them, what is it they spray and treat the hay with.... HS
   / Hay Customers? #20
I've been making hay for over 25 years. I have lots of 30-60 acre fields of various grasses to bale. At this point I put up 600 to 1000 round bales a year for my own use. Occasionally I have to buy additional. We only get 1 cut around here.
I am thinking of making a change and might get back into making some small squares. That is a lot trickier than rounds.
Why do you ask?
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2022 Morbark Eeger Beever 1215 Brush Chipper (A56857)
2022 Morbark Eeger...
LOT: (36) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #2 Grease (A59076)
LOT: (36) 14 Oz...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
2018 Peterbilt 389 Wet Kit T/A Sleeper Cab Truck Tractor (A55973)
2018 Peterbilt 389...
