Box Scraper Having trouble with quick attach
/ Having trouble with quick attach #1
N2fish
Aylett, va
John Deere 2305
I bought a quick attach from Northern Equipment for my John Deere 2305, new toy. Most of my attachments seem to attach ok, but my box scraper pins are to short, can I simply buy longer pins?
/ Having trouble with quick attach #2
I have not looked for them but a box scraper puts a lot of torque on the pins and longer ones sound like they would bend or bend what they are attached to. I looked at getting a similar quick hitch but my box scraper would have been to narrow. So I went with pat's quick hitch setup.
/ Having trouble with quick attach #3
You may be able to find some longer pins depending on what length the original pins are. I would not be worried about extra stress from the longer pins on a smaller tractor. Is the top link spacing correct?
/ Having trouble with quick attach #4
Most of the quick hitch adaptor bushings have two different hole spacings, this might provide you with enough extra length to work. I agree with Roger that you should be able to use a longer pin with the 2305. You can also use cat 2 pins with QH adaptor bushings that are longer too.
/ Having trouble with quick attach #5
My box blade was set up with too narrow a pin spacing also and after thinking about the amount of force put on the pins with the digging and gravel spreading I planned on doing I didn't think longer pins would last too long.
Several HD blades come with pin setups like this, so I added a few plates and used a long bolt with the correct diameter bushings to copy something similar to this picture, works great, and I don't think I'll have any trouble with bending any mounts.
( thanks to EA for the pic)
/ Having trouble with quick attach #6
Is this a king kutter xb box blade?
TAKEUCHI TL6R SKID STEER (A65053)
TAKEUCHI TL6R SKID...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
