Box Scraper Having trouble with quick attach
/ Having trouble with quick attach #1
N2fish
Aylett, va
John Deere 2305
I bought a quick attach from Northern Equipment for my John Deere 2305, new toy. Most of my attachments seem to attach ok, but my box scraper pins are to short, can I simply buy longer pins?
/ Having trouble with quick attach #2
I have not looked for them but a box scraper puts a lot of torque on the pins and longer ones sound like they would bend or bend what they are attached to. I looked at getting a similar quick hitch but my box scraper would have been to narrow. So I went with pat's quick hitch setup.
/ Having trouble with quick attach #3
You may be able to find some longer pins depending on what length the original pins are. I would not be worried about extra stress from the longer pins on a smaller tractor. Is the top link spacing correct?
/ Having trouble with quick attach #4
Most of the quick hitch adaptor bushings have two different hole spacings, this might provide you with enough extra length to work. I agree with Roger that you should be able to use a longer pin with the 2305. You can also use cat 2 pins with QH adaptor bushings that are longer too.
/ Having trouble with quick attach #5
My box blade was set up with too narrow a pin spacing also and after thinking about the amount of force put on the pins with the digging and gravel spreading I planned on doing I didn't think longer pins would last too long.
Several HD blades come with pin setups like this, so I added a few plates and used a long bolt with the correct diameter bushings to copy something similar to this picture, works great, and I don't think I'll have any trouble with bending any mounts.
( thanks to EA for the pic)
/ Having trouble with quick attach #6
Is this a king kutter xb box blade?
213135 (A64276)
213135 (A64276)
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
2001 Volvo Sleeper (A62613)
2001 Volvo Sleeper...
Patterson water pump (A59230)
Patterson water...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
