Hauling a DK40
/ Hauling a DK40 #1
Jklatham
Memphis
Kubota L3400
Sorry in advance if this is not the right forum but... About to buy a DK40 after looking mainly at a Kubota L3400 then it dawned on me how much more the Kioti weighs. First of all, I can't find a weight for the FEL on the Kioti site and second, all I have to tow the thing is an 08 GMC Sierra 1500 4x4 and a 18' 7000# trailer. I was comfortable with hauling the weight of the Kubota but geez, it's a big jump in weight to the DK40. I know the numbers say It shouldn't be a problem but I'm a rookie at this and I don't want to trash my truck hauling a tractor. Maybe I should get the tractor first and then a new truck to haul the tractor:D What do ya'll think?:confused:
/ Hauling a DK40 #2
Main thing will be getting your tongue weight right where you want it. Chain the tractor down good and away you go. Press the tow-haul button and don't just hold it to the floor when pulling a hill or taking off from a stop. Does your trailer have brakes??? There will be a good bit of weight pushing you when you are trying to stop.
/ Hauling a DK40
Regrettably, I don't have brakes. Is that something that can be added or do I need to look for a new trailer. By getting the tongue weight right is that balancing the load?
/ Hauling a DK40 #4
I think the numbers are a problem. First let's look at the trailer:
The 7000 lb trailer weighs about 2000 lbs including the binders and chains. This only leaves 5000lbs for the tractor, loader, any implements, and also the loaded tires if you did that.
My CK30 weighs about 4500 lbs with loader and one 500 lb implement on the back. I use a 10k rated trailer to haul it.
So what do you think that your DK40 weighs? Assume 1000 lbs for the loader with bucket.
Your truck is likely rated to tow the load if you believe the bogus "tow rating" but you may find that adding the 10-15% tongue weight will push you over your GVWR which is the typical weak link of a 1500 series truck.
Is this a one time tow or a regular tow trip? I tow mine all the time and I started out with a 1500 GM product which actually worked pretty well and now I have a diesel F350 which isn't really faster but is much more stable.
/ Hauling a DK40 #5
You need brakes. Your owner's manual will require brakes on a trailer if it is over some small weight like 1000#. You need a bigger trailer with brakes. Here's a photo of mine from last weekend. Your DK40 is much bigger.
By balancing the load you will get the tongue weight right. You need 10-15% of the total weight to be on the tongue. The way you do this is by moving the tractor forward or back on the trailer to put more or less weight on the tongue.
You will also find that you are required by your GM hitch to have a set of weight distribution bars on the hitch system. Not just a simple ball.
You're going to love it.
On edit: you can add brakes to almost any non-braked axle for pretty small money. Do it on both axles.
/ Hauling a DK40
I'm getting the tractor primarily for myself and the 160 acres of trees, hills (not all mine) and my 1.5 mile driveway. I also build houses (not right now of course) and would like to do what I've been paying others to do, so I may be toting it around some when the market comes back. I was really shocked when I saw the weight and thought that it might be an issue. If I upgrade the trailer would any of you feel comfortable towing it with a half ton?
/ Hauling a DK40 #7
I think you need more truck and trailer as well as brakes on all 4 wheels.
You may be ahead with the Kubota and just add weights to it when if needed.
No brakes i think he said.
i think you need a better trailer .
I would not.
/ Hauling a DK40 #8
A heavy weight isn't always an advantage as you are begining to find out.
How many sacrifices are you willing to make in order to accommodate the extra weight?
Are you ready to make them?
If so go for it or select a smaller / liter tractor.
Only you can decide.
Whatever you do ; do it safely.
/ Hauling a DK40 #9
I think you need brakes for sure.
I think you may need a stronger trailer although not sure what your machine weighs. Likely you'll be over.
I would not expect your truck to have a bunch of trouble hauling and with brakes on the trailer stopping should not be a problem either.
I'm thinking you need a 10K trailer.
I would not let the trailer dictate the machine I purchase.
Joel
/ Hauling a DK40
Thanks to all...I appreciate the info as I've never had to deal with hauling something so close to the max weight my truck can tow. I agree that I need to look for a larger trailer. The DK 40 comes in around 4000# +loader 1000#+ box blade 500# or maybe even a backhoe (who knows how heavy?:rolleyes:) I'll probably just use it around the house until I can work out the truck/trailer issues. There's too many benefits to the DK40 to give it up for a smaller tractor that I'll just trade in a few years.
/ Hauling a DK40 #11
So you have chosen the DK40. Good. You should anticipate the loader and backhoe combo as your loaded weight. A BH weighs about 1000+ lbs. So you're in the 6000 lb machine range. Add chains and fuel say 6500#. My 10k trailer weighs 2500 all by itself so your trailer weight would be 8500 lbs. Oh yes, you need a 10k rated trailer.
Most modern trucks like your 2008 have very high tow ratings and lots of high end HP. You will have to investigate to find the truck's empty weight, the GCWR, and the the allowable GVWR which will tell you if the truck can handle the trailer, and the tongue weight.
The trailer has brakes. Don't worry about stopping the load so long as it falls within your truck's ratings.
Finally, this is a commercial application. You are going to need commercial insurance to haul this machine for your business so you will want to see if the gov't or your insurer has any special CDL requirements and be especially aware of having the proper safety equipment.
Myself, towing an 8500 lb trailer, I would be looking for a 3/4 or one ton truck. That's a lot of weight. Your half ton truck probably weighs about 5500# with soft suspension and will be challenged to haul an 8500# monster even if it is within the ratings.
/ Hauling a DK40 #12
I like your thinking. Lets stimulate this economy as much as we can. I'm not sure my better half would fall for that scenario though. :rolleyes:
Steve
/ Hauling a DK40
Thanks, the 'commercial' side of it never entered my mind. I'll definately check it out. Looks like the Kioti will be staying at the house until I can get a new trailer...and truck. What the h*ll, kids don't need no stinkin college:D
/ Hauling a DK40 #14
You already have the advise for hauling that you need here. Just thought I'd say, I bought a trailor 4 years ago when I bought my tractor planning to haul it. I loaded it once to see what it looked like and have never loaded it since. I did however, find out rather quckly I needed jacks on the back of the trailor to keep the tongue on the ground when I drove up on the trailor.. :)
/ Hauling a DK40
DEFINATELY agree with the jacks...several years ago I watched my brother in law try to load an old Ford tractor when it lifted the back of his truck off the ground. The trailer and truck jack knifed and the whole lot rolled into a small ditch. He was lucky, all it did to him was break his collar bone. All that metal in a heap was a mess!:eek:
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61574)
2018 Freightliner...
PALLET OF APPROX (12) 2" X 6" X 55 1/2" TUBING (A64280)
PALLET OF APPROX...
(2) DOUBLE AXLE TRAILER FENDERS (A64280)
(2) DOUBLE AXLE...
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
APPROX (12) 8" & 10" I BEAM UP TO 12' (A64280)
APPROX (12) 8" &...
