Front-End Loader Hardy loaders
/ Hardy loaders #1
foreman81
JD 2210
I'm looking for info on Hardy brand loaders (not the same as the sprayers Hardi). Is it canadian or american made? They don't seem to have a website. They make loaders for tractors all shapes and sizes.
/ Hardy loaders #3
The ones you're looking for are from Quebec. I can not find a site for them either. Try getting ahold of Bourbanais,or check the dealer brand area of the AgDealer www.agdealer.com
Here's some contact info for Hardy.
100 St Arthur Street
Portneuf Station,Quebec
418-286-6621
/ Hardy loaders #4
I own a Hardy loader, model ST85 (for Standard), which is mounted on my Belarus 525 tractor. They have a wide range of loaders, designed for tractors less than 20HP (model 25) up to 100HP (model 105). They do not have a web site and sell only through dealers. A call should get you information on the closest dealer. The loader is quick attach/detach, as it was demonstrated to me. I keep the loader attached at all times. There are several accessories available. A choice of buckets (snow, material w/wo "manure forks" and a manure bucket with a dirt plate (which turns the manure bucket into a material type bucket). Also offer pallet forks and round bale fork (these replace the bucket).
/ Hardy loaders #5
I have a Hardy Loader (I think it's a model 85) on a Zetor 5245. It has been an excellent loader. Lots of power, simple design. In 17 years I have had to replace seals in one cylinder once. I take it off when I am cutting hay to remove the weight from the tractor - It takes about 20 minutes and one wrench.
For what its worth. There are a couple of photos from this <A target="_blank" HREF=http://www.agdealer.com/>link</A> Type in Hardy Loader in the Equipment Search box on the left side
Bob
2023 Boxer 700HDX Compact Skid Steer (A63116)
2023 Boxer 700HDX...
Willmar 4550 Wrangler Articulating Loader (A63118)
Willmar 4550...
2008 Ford E350 Armored Car (A64047)
2008 Ford E350...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
LANGELIFT 4000# - 30" X 30" HYD LIFT TABLE (A63290)
LANGELIFT 4000# -...
EZ Trail 3400 (A63118)
