Hard start, smoke, then knocks, then fine?
/ Hard start, smoke, then knocks, then fine?
the glow plugs are all new - and all connected via a bus bar - im not sure how it cant work - the low compression suggestion is probably the most likely.
/ Hard start, smoke, then knocks, then fine? #23
If you are starting it in 50F temps, I can't see how glow plugs are even needed. I use a bobcat with glow plugs which starts in 40F weather within 2 seconds without even touching the glow plugs.
I'm voting for low compression as well. Maybe valves not seating well/worn out?
after a good 'italian tuneup' = thrash the **** out of it, plus tightening the #3 injector up might help....
/ Hard start, smoke, then knocks, then fine? #25
If you run your glow plugs, it's heating the cylinder. Opening the de-compression valve, spinning the motor for a while before letting go is going to suck in a lot of cold air, making the glow plugs almost useless. Verify your glow plugs are getting power while cranking, if they are supposed to like I think I read. The blueish white smoke is cold unburnt fuel. I don't think things are getting heated up enough. Compression may be a culprit as well. Air being sucked into a fuel line will make the engine knock, if you have fuel leaking out, then there is a chance you have air leaking in.
New/Unused SDLL60 Mini Track Loader (A65583)
New/Unused SDLL60...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
