Hard start, smoke, then knocks, then fine?
/ Hard start, smoke, then knocks, then fine?
the glow plugs are all new - and all connected via a bus bar - im not sure how it cant work - the low compression suggestion is probably the most likely.
/ Hard start, smoke, then knocks, then fine? #23
If you are starting it in 50F temps, I can't see how glow plugs are even needed. I use a bobcat with glow plugs which starts in 40F weather within 2 seconds without even touching the glow plugs.
I'm voting for low compression as well. Maybe valves not seating well/worn out?
after a good 'italian tuneup' = thrash the **** out of it, plus tightening the #3 injector up might help....
/ Hard start, smoke, then knocks, then fine? #25
If you run your glow plugs, it's heating the cylinder. Opening the de-compression valve, spinning the motor for a while before letting go is going to suck in a lot of cold air, making the glow plugs almost useless. Verify your glow plugs are getting power while cranking, if they are supposed to like I think I read. The blueish white smoke is cold unburnt fuel. I don't think things are getting heated up enough. Compression may be a culprit as well. Air being sucked into a fuel line will make the engine knock, if you have fuel leaking out, then there is a chance you have air leaking in.
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
(32) Kinze Seed Tubes (A65640)
(32) Kinze Seed...
2022 EZ-GO ELITE...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2005 Polaris Sportsman 700 EFI (A66408)
2005 Polaris...
