Hard line damage
/ Hard line damage #1
E/S
Reno, NV
Kubota M8540HDC12-1 4x4 w/ Cab
Hooked a tree limb with my loader and damaged my hard line.
My question is do I have to replace the hard line, I'm scared to try and bend it back in place.
/ Hard line damage #2
If its not leaking and not in the way of any loader movement ... maybe just leave it.
/ Hard line damage #3
2nd that if it's not pinched too much to cut down on the flow. I would at least wrap a piece of garden hose around it to keep it from rubbing on the support like in the 1st pic to prevent more wear.
/ Hard line damage #4
Good advice Beeforty!
/ Hard line damage
It's not leaking or rubbing (right now).
/ Hard line damage #6
This is what I would do..and just keep an eye on it in case a pin hole develops.
Remember, this is high pressure hydraulic fluid...don't run your fingers over it.
/ Hard line damage #7
Odds are that if you try to straighten that kink it will crack and start to leak or it will kink on the other side and definitely require replacement. I agree with the others leave it alone until you get a replacement.
Roy
/ Hard line damage #8
I know it is not recommended but I have brazed them when they get a pinhole in em (temporary fix) but if you dont need to bend it back then leave it be:thumbsup:
/ Hard line damage #9
I would not want to try to straighten it by bending it back. Instead I would want to re round the kinked area. FWIW, I would drill out an appropriate hex nut to the tubing OD and cut the nut in two thru opposing points. Then file/round/polish all sharp edges that would touch the tube. Then Id clamp it around the tube with Vise Grips, squeezing and re orienting it a little at a time to make the cross section as round as possible again. The bend would straighten somewhat while doing this. :confused3:
larry
/ Hard line damage #10
I've done this too. I decided not to fix what wasn't broke.
/ Hard line damage #11
larry
Never would have thought of doing it that way.
Great Idea:thumbsup:
/ Hard line damage #12
Add some wear protection around the bend.
Look at the rust and maybe do something about that.:)
Find out what all you need for replacement so you are prepared;)
/ Hard line damage
Ok, you convinced me. I am padding the line and ordering a replacement.
Thanks for all your input.
E/S
/ Hard line damage #14
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=234306"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=234307"/>
You can replace it with regular ole' hydraulic hose if you have to get by. Trying to bend back a kinked hardline never works...
2011 Jeep Grand Cherokee AWD SUV (A61574)
2011 Jeep Grand...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
Claas Lexion 700 Series Folding Grain Bin Panels (A63117)
Claas Lexion 700...
2011 FREIGHTLINER M2 112 CNG  6X4 T/A DAYCAB TRACTOR (A59912)
2011 FREIGHTLINER...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2026 Kearney 7'x16' Trailer (A64119)
2026 Kearney...
