Hard line damage
/ Hard line damage #1
E/S
Gold Member
Reno, NV
Kubota M8540HDC12-1 4x4 w/ Cab
Hooked a tree limb with my loader and damaged my hard line.
My question is do I have to replace the hard line, I'm scared to try and bend it back in place.
/ Hard line damage #2
If its not leaking and not in the way of any loader movement ... maybe just leave it.
/ Hard line damage #3
2nd that if it's not pinched too much to cut down on the flow. I would at least wrap a piece of garden hose around it to keep it from rubbing on the support like in the 1st pic to prevent more wear.
/ Hard line damage #4
Good advice Beeforty!
/ Hard line damage
It's not leaking or rubbing (right now).
/ Hard line damage #6
This is what I would do..and just keep an eye on it in case a pin hole develops.
Remember, this is high pressure hydraulic fluid...don't run your fingers over it.
/ Hard line damage #7
Odds are that if you try to straighten that kink it will crack and start to leak or it will kink on the other side and definitely require replacement. I agree with the others leave it alone until you get a replacement.
Roy
/ Hard line damage #8
I know it is not recommended but I have brazed them when they get a pinhole in em (temporary fix) but if you dont need to bend it back then leave it be:thumbsup:
/ Hard line damage #9
I would not want to try to straighten it by bending it back. Instead I would want to re round the kinked area. FWIW, I would drill out an appropriate hex nut to the tubing OD and cut the nut in two thru opposing points. Then file/round/polish all sharp edges that would touch the tube. Then Id clamp it around the tube with Vise Grips, squeezing and re orienting it a little at a time to make the cross section as round as possible again. The bend would straighten somewhat while doing this. :confused3:
larry
/ Hard line damage #10
I've done this too. I decided not to fix what wasn't broke.
/ Hard line damage #11
larry
Never would have thought of doing it that way.
Great Idea:thumbsup:
/ Hard line damage #12
Add some wear protection around the bend.
Look at the rust and maybe do something about that.:)
Find out what all you need for replacement so you are prepared;)
/ Hard line damage
Ok, you convinced me. I am padding the line and ordering a replacement.
Thanks for all your input.
E/S
/ Hard line damage #14
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=234306"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=234307"/>
You can replace it with regular ole' hydraulic hose if you have to get by. Trying to bend back a kinked hardline never works...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
2014 Sullair 185DPQ 100psi Towable Air Compressor (A61572)
2014 Sullair...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
2025 JMR Stump Bucket Skid Steer Attachment (A61572)
2025 JMR Stump...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
