Hard line damage
/ Hard line damage #11
I would not want to try to straighten it by bending it back. Instead I would want to re round the kinked area. FWIW, I would drill out an appropriate hex nut to the tubing OD and cut the nut in two thru opposing points. Then file/round/polish all sharp edges that would touch the tube. Then Id clamp it around the tube with Vise Grips, squeezing and re orienting it a little at a time to make the cross section as round as possible again. The bend would straighten somewhat while doing this. :confused3:
larry
Never would have thought of doing it that way.
Great Idea:thumbsup:
/ Hard line damage #12
Add some wear protection around the bend.
Look at the rust and maybe do something about that.:)
Find out what all you need for replacement so you are prepared;)
/ Hard line damage
Ok, you convinced me. I am padding the line and ordering a replacement.
Thanks for all your input.
E/S
/ Hard line damage #14
E/S said:
Hooked a tree limb with my loader and damaged my hard line.
My question is do I have to replace the hard line, I'm scared to try and bend it back in place.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=234306"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=234307"/>
You can replace it with regular ole' hydraulic hose if you have to get by. Trying to bend back a kinked hardline never works...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
BRAD CO. TRENCHER (A60736)
BRAD CO. TRENCHER...
2025 AGT Industrial MX-CRT23 (A60463)
2025 AGT...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2001 Keystone Montana 3575RL 36ft. T/A 5th Wheel Travel Trailer (A59231)
2001 Keystone...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
