Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #7,381
Anyone have any experience with H-F's pneumatic tire casters??? My wife wants me to make an "all terrain" grocery cart that she can use in the garden.
I would be cautious about any small tire from HF that used a tube. My experience is that they won't hold air for very long.
/ Harbor Freight Tools that don't suck #7,382
I've tried several and none last long but on my wife's garden wagon I replaced them with the solid tires and she is very happy with them.The down side is that they are about $15 each but if she's happy it's well worth it.
/ Harbor Freight Tools that don't suck #7,384
That's why they put the Slime on the adjacent shelf.:rolleyes:
/ Harbor Freight Tools that don't suck #7,385
Small tires from HF are a waste since the air leaks out so fast. On the other hand, their hard rubber tires are excellent if not left out in the rain and snow.
/ Harbor Freight Tools that don't suck #7,386
Does that really work? I assumed their tubes leaked through all surfaces, not just the outer perimeter where the Slime will settle.
/ Harbor Freight Tools that don't suck #7,387
I assume Slime settles when the vehicle isn't moving. If there is enough to fill the diameter of the tube in the bottom at rest then eventually all the micro holes would clog and stop leaking. I have no evidence, just speculation.
/ Harbor Freight Tools that don't suck #7,388
Just used my HF step drill for the first time on some 1/8" thick angle iron. Worked great once I penetrated all the way through. But wondering if I need to use a different pilot bit to start? I have no doubt I could easily drill much larger holes once the tip is through even in thicker material. I liked how I could easily clean up/deburr the backside too.
/ Harbor Freight Tools that don't suck #7,389
I've never used it either. I thought it was intended for small thorn punctures so it didn't occur to me it might be a general remedy for HF's porous synthetic rubber.
/ Harbor Freight Tools that don't suck #7,390
I have a general drilling question: I have plenty of plumber's pipe thread cutting oil. Is this the same thing, or suitable, as oil for a drill press?
/ Harbor Freight Tools that don't suck #7,391
I've used it for big bore drilling into cast iron which is done really slow. Higher speed drills might make it smoke.
/ Harbor Freight Tools that don't suck #7,392
What advantage to you see over using the FEL? I'm assuming the FEL is blocked and the mower secured to the FEL so it cannot slip as those are easy and necessary for safety.
I trust my FEL much more than I would one of those mower lifts AND my mower weighs 800# without any mud and grass debris underneath so I will continue to use the FEL to lift my mower.
I bolted on a chain loop on the front of my mower just for the FEL lift. I just hook my lift chain hook to the mower and the other end in my FEL chain hook and up it goes. I can lift it nearly vertical with ease so hosing out the mud and gunk is easy. It works just as well for changing the mower blades also.
I like to live dangerously, so no 2x4 blocking used either (Safety police jump on it if you like). After thinking about it and deciding that the possibility of the 4700# working load of the chain lifting partial weight of a 800# mower breaking is NIL and also the possibility of a hydraulic hose bursting is really low, I don't mess with 2x4 blocking (4x4 likely would work)which might not hold the load anyway should the impossible happen.
If I were really paranoid about the FEL failing, I would make some 2x2 angle blocks to use on the FEL cylinders as stops.
/ Harbor Freight Tools that don't suck #7,393
FELs don't fail catastrophically often however kids or animals might bump the FEL joystick or other unforeseen events can result in dropping the mower. I'm pretty comfortable with a simple 2x4 as a "safety chain" blocking the loader while working under the mower. If all I was doing was hosing the underside of the mower though I wouldn't use anything.
/ Harbor Freight Tools that don't suck #7,395
I too thought the FELs were infallible. That is until this past winter my son and I were clearing so downed trees for the burn pile, with the FEL set up at about waist high. After a few minutes he walked by the front of the FEL loaded with about 600# of logs already, and WHAM! The bucket w/forks and logs hit the ground. There was nothing wrong with the tractor though. Somehow when he parked and set the FEL at the height he wanted he didn't get it totally in either Up or Down. Then with the engine off, the hydraulic pressure neutralized some, releasing the FEL.
I had never before nor ever afterwards had that happen. But had either of us been near or under the FEL, there would have been funeral plans to make.
Two things that I've learned now, never work under a FEL without a support, and of course, never ever work under anything with a bumper jack or high-lift jack. You're right - FELs don't OFTEN fail, but the only need to do that once if you're working underneath one. Even a 2x4 would be a good safety chain, assuming the FEL was empty. As I get older, I think I'm getting more cautious. Perhaps seeing first hand that accidents do happen is making me that way.
/ Harbor Freight Tools that don't suck #7,396
That is until ...
Similar experience here but with older equipment. Loader hoses were aged, shabby, sweating (photo) when I bought the Yanmar. It needed cylinder seals also due to leakdown. I figured no problem if I fixed other stuff first.
But I unexpectedly snagged the front of the bucket moving at low speed, due to leakdown of the curl circuit, which curled the bucket forward and stopped me cold with the curl hose burst. No damage. But at higher speed it could have broken something or jammed me into the steering wheel. Don't Trust Old Hydraulics! I've replaced all the cylinder seals and most of the hoses since, no subsequent problems.
/ Harbor Freight Tools that don't suck #7,397
HF Needle Scaler:
I mentioned a few pages back this was ideal, the only tool that could do it, to clean around a pipe that entered a concrete septic tank but wasn't properly sealed there.
138609d1251694554t-cheap-air-chisel-removing-tiles-p1190583rneedlescaler-jpg
Here's my old post describing the project and with a larger photo. I definitely recommend this tool even though I've never used it since. It was the only thing that could do the job.
http://www.tractorbynet.com/forums/...ap-air-chisel-removing-tiles.html#post1746855
/ Harbor Freight Tools that don't suck #7,398
I propped my empty FEL with a 2 x 4 as I have had a slow leaky valve for some time now.*
Well even with slow slow leak the 2 x 4 bent like a pretzel , OK it was slow and had I been under I could have slipped out had I been under.
And my tractor only has a 4 ft bucket.
*nothing I can't cope with under general working conditions.
/ Harbor Freight Tools that don't suck #7,399
You do realize that we lost a member here - Mikim - doing exactly what you do. The chain slipped and his they found him dead under the mower. He left behind a very devastated and grieving family. And I lost a very good friend.
/ Harbor Freight Tools that don't suck #7,400
Very sad and a good reminder for those of us that work alone and on a time crunch most of the time. Did this happen recently?
2019 CATERPILLAR 289D SKID STEER (A60429)
2019 CATERPILLAR...
UNUSED X-STAR 101"X20' LOADING RAMP (A60430)
UNUSED X-STAR...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2004 Volvo VNM S/A Day Cab Truck Tractor (A59230)
2004 Volvo VNM S/A...
2021 CATERPILLAR 306CR EXCAVATOR (A60429)
2021 CATERPILLAR...
