Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #7,381
Anyone have any experience with H-F's pneumatic tire casters??? My wife wants me to make an "all terrain" grocery cart that she can use in the garden.
I would be cautious about any small tire from HF that used a tube. My experience is that they won't hold air for very long.
   / Harbor Freight Tools that don't suck #7,382
I've tried several and none last long but on my wife's garden wagon I replaced them with the solid tires and she is very happy with them.The down side is that they are about $15 each but if she's happy it's well worth it.
   / Harbor Freight Tools that don't suck #7,384
That's why they put the Slime on the adjacent shelf.:rolleyes:
   / Harbor Freight Tools that don't suck #7,385
Small tires from HF are a waste since the air leaks out so fast. On the other hand, their hard rubber tires are excellent if not left out in the rain and snow.
   / Harbor Freight Tools that don't suck #7,386
Does that really work? I assumed their tubes leaked through all surfaces, not just the outer perimeter where the Slime will settle.
   / Harbor Freight Tools that don't suck #7,387
I assume Slime settles when the vehicle isn't moving. If there is enough to fill the diameter of the tube in the bottom at rest then eventually all the micro holes would clog and stop leaking. I have no evidence, just speculation.
   / Harbor Freight Tools that don't suck #7,388
Just used my HF step drill for the first time on some 1/8" thick angle iron. Worked great once I penetrated all the way through. But wondering if I need to use a different pilot bit to start? I have no doubt I could easily drill much larger holes once the tip is through even in thicker material. I liked how I could easily clean up/deburr the backside too.
   / Harbor Freight Tools that don't suck #7,389
I've never used it either. I thought it was intended for small thorn punctures so it didn't occur to me it might be a general remedy for HF's porous synthetic rubber.
   / Harbor Freight Tools that don't suck #7,390
I have a general drilling question: I have plenty of plumber's pipe thread cutting oil. Is this the same thing, or suitable, as oil for a drill press?
Mac 3200 Chainsaw (A57454)
Mac 3200 Chainsaw...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
New/Unused Heavy Duty Brush Cutter (A57454)
New/Unused Heavy...
gps trailers (A56859)
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
LOT: (2) Piece Mac Tools TRCH Portable 1000 Tool Box w/Contents: Lower Tool Box: 18-Drawers, Upper (A59076)
LOT: (2) Piece Mac...
