Harbor freight quick hitch question
/ Harbor freight quick hitch question #1
gd165623
I have the quick hitch and new top hook . i want to replace top hook bolts with pins.It is metric so 1/2 inch pins are too big---should i go with 7/16 pins or what Thanks
/ Harbor freight quick hitch question #3
I hadn't seen that. It just doesn't seem like something our local store would carry.
What size are the pins now?
13mm = 0.512", and your 1/2" pin should fit.
12mm = 0.472", I would probably ream it to 1/2"
11mm = 0.433", ream to 7/16 (0.4375")
10mm = 0.393", slightly larger than 3/8" (0.375")
In general I'd rather a tight fit than a loose fit, but too tight is also a problem for some things, especially pins that have to be frequently removed.
If you are enlarging a hole, make sure you don't remove too much material that you compromise the base structure.
/ Harbor freight quick hitch question #4
i want to replace top hook bolts with pins.It is metric so 1/2 inch pins are too big.
I have a harbor freight quick hitch and drilled them out. They are only slightly under 1/2" so there is very little material removed when you drill them, most of the material is paint, not steel. I would have no concerns about drilling one out.
/ Harbor freight quick hitch question #5
Well sell the correct pins made just for this:
/ Harbor freight quick hitch question #6
Check your stores website. They will indicate if it’s in stock or not.
They also don’t have it out on the floor. To buy one go to the front of the store where the tag kiosk is (for oversized items); where you grab a tag/coupon to take to register to buy.
/ Harbor freight quick hitch question #7
It's easiest just to go this route for sure.
/ Harbor freight quick hitch question #8
Personally, largely because none of my new to me older implements, are QH compatible, I ended up going with a style similar to Pat’s system. The brand I thought they are no longer show them. I got them for about 1/2 what Pat’s listed for at the time. In general I’n very happy with them. Pat’s have some features that would be nice that mine don't have, but….
Yes I have to get off to connect the the Top Link, but if it is a PTO implement. You are getting off anyway.
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A67714)
2013 POLAR TANK...
2013 FORD F-550 SUPER DUTY (A67714)
2013 FORD F-550...
2018 FORD TRANSIT KUV (A67714)
2018 FORD TRANSIT...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A67714)
2008 FOREST RIVER...
Baby Goat Decorative Statue (A66738)
Baby Goat...
