Harbor freight quick hitch question
/ Harbor freight quick hitch question #1
gd165623
Member
I have the quick hitch and new top hook . i want to replace top hook bolts with pins.It is metric so 1/2 inch pins are too big---should i go with 7/16 pins or what Thanks
/ Harbor freight quick hitch question #3
I hadn't seen that. It just doesn't seem like something our local store would carry.
What size are the pins now?
13mm = 0.512", and your 1/2" pin should fit.
12mm = 0.472", I would probably ream it to 1/2"
11mm = 0.433", ream to 7/16 (0.4375")
10mm = 0.393", slightly larger than 3/8" (0.375")
In general I'd rather a tight fit than a loose fit, but too tight is also a problem for some things, especially pins that have to be frequently removed.
If you are enlarging a hole, make sure you don't remove too much material that you compromise the base structure.
/ Harbor freight quick hitch question #4
i want to replace top hook bolts with pins.It is metric so 1/2 inch pins are too big.
I have a harbor freight quick hitch and drilled them out. They are only slightly under 1/2" so there is very little material removed when you drill them, most of the material is paint, not steel. I would have no concerns about drilling one out.
/ Harbor freight quick hitch question #5
Well sell the correct pins made just for this:
/ Harbor freight quick hitch question #6
Check your stores website. They will indicate if it’s in stock or not.
They also don’t have it out on the floor. To buy one go to the front of the store where the tag kiosk is (for oversized items); where you grab a tag/coupon to take to register to buy.
/ Harbor freight quick hitch question #7
It's easiest just to go this route for sure.
/ Harbor freight quick hitch question #8
Personally, largely because none of my new to me older implements, are QH compatible, I ended up going with a style similar to Pat’s system. The brand I thought they are no longer show them. I got them for about 1/2 what Pat’s listed for at the time. In general I’n very happy with them. Pat’s have some features that would be nice that mine don't have, but….
Yes I have to get off to connect the the Top Link, but if it is a PTO implement. You are getting off anyway.
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
iDrive TDS-2010H...
2019 PETERBILT 389 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 389...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
