California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,866
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
If you are going to redesign for fully automatic hitch-up, so you can just back up to the implement and lift - Then here's another approach. It should be simple from a geometry perspective but I'm not so sure about strength.
I don't think anything is going to hitch up easily so long as the top hook bumps into a cross-bolt below the implement's top pin.
Simply move each implement's top pin forward a couple of inches. This would get it out of the plane of the other bolts just beneath, so you could back the hook under that pin.
A pair of triangular plates could be put on each implement, with their implement-side holes spaced to match the existing pin and the cross-bolt below it. The forward hole on the new triangle plates could be drilled custom to give all the implements a standard height, lower pins to upper pin.
