Hand Throttle
/ Hand Throttle #1
Kubota 2350
Platinum Member
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
I have a 4310 E Hydro and I can't seem to get the hand throttle to hold where I put it.
I've adjusted it 3 different times, it works for awhile than it'll float back down while running and loose RPM's.
The service manual that I have doesn't give a good brake down of this part, does anyone know if there is something that wears out in this area?
/ Hand Throttle #2
Learn how to use JDparts;):thumbsup:
Most common problem is one or both friction disks (#2) are cracked or distorted.
/ Hand Throttle
Thanks, that explains a lot, where do I find JD parts you speak of?
A trip to the dealer in the morning is in order.
/ Hand Throttle #4
www.jdparts.com
It the same basic parts system the dealer uses at the parts counter, and it's FREE to register! Another benefit of buying green;)
Just remember to "think like a parts guy"
/ Hand Throttle
Well replaced both the friction washers, spring washer, and a new lock nut.
Working great for now, hopefully it stays that way.
/ Hand Throttle #6
It should...for a while anyway. Where the old ones cracked?
/ Hand Throttle
No cracks, just hardened a bit.
I think the problem was actually the lock nut not holding.
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2022 EZ-GO ELITE...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
2018 Deere 770G (A64126)
2018 Deere 770G...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
