Hand Throttle
/ Hand Throttle #1
Kubota 2350
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
I have a 4310 E Hydro and I can't seem to get the hand throttle to hold where I put it.
I've adjusted it 3 different times, it works for awhile than it'll float back down while running and loose RPM's.
The service manual that I have doesn't give a good brake down of this part, does anyone know if there is something that wears out in this area?
/ Hand Throttle #2
Learn how to use JDparts;):thumbsup:
Most common problem is one or both friction disks (#2) are cracked or distorted.
/ Hand Throttle
Thanks, that explains a lot, where do I find JD parts you speak of?
A trip to the dealer in the morning is in order.
/ Hand Throttle #4
www.jdparts.com
It the same basic parts system the dealer uses at the parts counter, and it's FREE to register! Another benefit of buying green;)
Just remember to "think like a parts guy"
/ Hand Throttle
Well replaced both the friction washers, spring washer, and a new lock nut.
Working great for now, hopefully it stays that way.
/ Hand Throttle #6
It should...for a while anyway. Where the old ones cracked?
/ Hand Throttle
No cracks, just hardened a bit.
I think the problem was actually the lock nut not holding.
1985 Ford F-250 Pickup Truck (A62613)
1985 Ford F-250...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
3'x8' Stack of Sheet Metal (A64127)
3'x8' Stack of...
Skid Steer Trailer Mover (A65640)
Skid Steer Trailer...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
