Hand Throttle
/ Hand Throttle #1
Kubota 2350
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
I have a 4310 E Hydro and I can't seem to get the hand throttle to hold where I put it.
I've adjusted it 3 different times, it works for awhile than it'll float back down while running and loose RPM's.
The service manual that I have doesn't give a good brake down of this part, does anyone know if there is something that wears out in this area?
/ Hand Throttle #2
Learn how to use JDparts;):thumbsup:
Most common problem is one or both friction disks (#2) are cracked or distorted.
/ Hand Throttle
Thanks, that explains a lot, where do I find JD parts you speak of?
A trip to the dealer in the morning is in order.
/ Hand Throttle #4
www.jdparts.com
It the same basic parts system the dealer uses at the parts counter, and it's FREE to register! Another benefit of buying green;)
Just remember to "think like a parts guy"
/ Hand Throttle
Well replaced both the friction washers, spring washer, and a new lock nut.
Working great for now, hopefully it stays that way.
/ Hand Throttle #6
It should...for a while anyway. Where the old ones cracked?
/ Hand Throttle
No cracks, just hardened a bit.
I think the problem was actually the lock nut not holding.
84in. Snow or Litter Skid Steer Bucket (A65640)
84in. Snow or...
Mini Skid Steer (A60352)
Mini Skid Steer...
2015 Bobcat T750 (A64126)
2015 Bobcat T750...
2022 EZ-GO ELITE...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2022 YANMAR VIO55-6A EXCAVATOR (A63276)
2022 YANMAR...
