H240 loader, leveling indicator issue
/ H240 loader, leveling indicator issue #1
fishrman
I think I may have already answered my own question after doing a bunch of research looking for a replacement spring. Seems I can buy the spring for about 125.00 but, in all honesty, I had no idea what it was even for till doing the research and therefore, I am not sure I should spend the money for a new one. Have used my machine off and on for 350 or so hours and never paid much attention to it till a branch got in it and I ended up bending it pretty badly. Does anyone actually use it or do you agree that I would be just as well without it? Shouldn't be to hard to take off. Thanks.
/ H240 loader, leveling indicator issue #2
Pic of what you are concerned about would help with some suggestions.
Referring to this: #14
/ H240 loader, leveling indicator issue #8
I use mine a lot to return the forks (and bucket) to parallel with the ground.
Can do that before the FEL arms are back down to working position. Very handy for what I use my forks and bucket for on the FEL. Can't imagine getting along without it, but some don't use the FEL for much.
This H240 may have self-leveling arms, can't tell for sure. If that is the case, prolly not needed so much.
I am not sure if it is self leveling or not. I just took it off and will try to straighten it up and put it back on. Thanks.
/ H240 loader, leveling indicator issue #12
On a H340, I had a sqeal for years that I couldn't figure out. Only on the curl function. I greased the hell out of the pins. Till I figured out it was that spring making that noise.
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
2011 ORTEQ TANK MANIFOLD (A63569)
2011 ORTEQ TANK...
2020 INTERNATIONAL LT625 6X4 TANDEM SLEEPER TRUCK (A59910)
2020 INTERNATIONAL...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
