Grounds
/ Grounds #11
Exactly my point. The conduit due to it's cross section and high resistance will not be the problem. The 12 GA wire will.
Electricity like water takes the path of lease resistance.
You realize that is an oversimplification, don't you? The current will actually split between the conduit and the Cu wire, in inverse proportion to the resistance of each path. So much more current will go through the lower-resistance Cu, but the Steel conduit will still carry a significant current load. I'd have to look up resistance values and calculate it out to be exact.
/ Grounds #12
There would be no welding current/voltage going back the conduit or the wiring if the conduit or box is isolated/insulated from the welding table.
Better yet, why not use plastic conduit & recp box.
No one said anything about a GFI Breaker yet as possibly a another option.
/ Grounds #13
Well obviously... but he was talking about it being metal and connected to the table...in which case there certainly would be. I think it would make the most sense to isolate it and use non-conductive conduit.
/ Grounds
Being a safety first type of guy, when I put electricity on a metal table I want that table to be grounded.
/ Grounds #15
How would the welder ground feed back through building electrical? The welder has a transformer the secondary winding gets power from the primary winding via magnetic inductance. unless the circuit is completed between the two welder leads there is no flow of current. The circuit would not be completed from just one lead to building ground :confused:
/ Grounds #16
If what you say was true I'd never been shocked while welding on the ground, but I have on many occasions even when my workpiece was on wooden horses.
I'd keep the utility circuit isolated from my bench. MikeD74T
/ Grounds #17
dirt clod is exactly correct on this issue. The welding current from your power supply is only trying to get back to it's source. ie the other side of the transformer lead, or from - to +. It just can't go anywhere else by the laws of electrical circuits.
Want to prove it?
Touch the stinger (only) to the outer metal case of your welder with the return lead disconnected from the welding machine. Nothing!
Problems crop up here where the ground lead from the welder is disconnected from the weld met and is in contact with earth ground along with the weld met. Then it indeed will try to follow the building electrical system ground all the way back to the ground lead of the welder.
Hopefully there is enough resistance in the circuit you won't get an arc and start looking for the problem.....but it does happen.
That my friend is why attaching the ground lead from your welding machine to a good clean surface is so very important.
And for the love of live itself always ground electrical outlets and metal boxes.
more people are killed every year with 120VAC than any other voltage in this country. Besides that, it's a code violation not to have the receptacle grounded.
Been there done that........aint smart.
Adams 16T Tender Body (A61307)
Adams 16T Tender...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
2013 PRATT INDUSTRIES GARDNER DENVER TRIPLEX FRAC PUMP (A60736)
2013 PRATT...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Clark C500-YS80 Forklift (A61166)
Clark C500-YS80...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
