Grillo 107d Brake Options
/ Grillo 107d Brake Options #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
/ Grillo 107d Brake Options #2
That's a 2007 or older model. You can retrofit them, but they're not as handy as the ones at the hand grips because you have to let go of the handlebar to actuate them.
Thanks for the response. My hands are to small for the grip brake levers.
Any suggestions on what I can do?
Sent from my iPad using TractorByNet
/ Grillo 107d Brake Options #4
First, shorten the sleeves as far as possible to make the reach as small as possible. Since they're turning brakes, you don't really need them to grip hard. I always shorten the brake lever sleeves and the steering column lock sleeve a Loooooong ways when setting up a machine.
/ Grillo 107d Brake Options #5
I don't know too much about the brake setup on a BCS, so don't know if this would work or not, but maybe you could adapt a stepped motorcycle/atv brake/clutch lever? One that has a dog leg to bring the lever portion closer to the grip? Not sure where it came from, but had one on a dirt bike for one of the kids many years ago - it let their smaller hands reach around the lever without having to adjust the cable all the way out. You could probably make one by bending the appropriate thickness rod stock, then weld a tab to fit your fulcrum/attachment point...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59912)
2019 ISUZU NPR 4X2...
100" Bucket (A64119)
24220 (A56859)
24220 (A56859)
2012 Ford Expedition SUV (A61574)
2012 Ford...
