grille guard
/ grille guard #1
hd5
Missouri
MF2705, MF135 XR4046H
I have a piece of shiny aluminum diamond plate. I think it would make a good insert for the grille guard, but concerned it might cut down on air flow.
I need to get something in there before I run a limb thru my grille.
/ grille guard #2
I don't have an insert in mine yet. I don't think I would use anything solid. I would go with expanded metal or similar so engine can breath. I think there is a thread with pics on here.
/ grille guard #4
I would think that, so long as you don't have the insert right up against the radiator fins, the air will still move through the radiator just fine. A tractor doesn't move fast enough to rely on air moving into the radiator, it just depends on the fan.
/ grille guard #5
I went with the expanded metal;after I speared my battery and lower grill.I prefer this over a solid piece of metal.
If you go with the metal;drill a bunch of small holes for a little better flow.
/ grille guard #6
What is the thickness of your expanded metal and is it 1/2" or larger expanded metal?
2022 SANY SY5OU EXCAVATOR (A63276)
2022 SANY SY5OU...
PALELT OF BED KNOCKERS & MISC PARTS (A64278)
PALELT OF BED...
2012 Toyota Camry Sedan (A64557)
2012 Toyota Camry...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
