grille guard
/ grille guard #1
hd5
Missouri
MF2705, MF135 XR4046H
I have a piece of shiny aluminum diamond plate. I think it would make a good insert for the grille guard, but concerned it might cut down on air flow.
I need to get something in there before I run a limb thru my grille.
/ grille guard #2
I don't have an insert in mine yet. I don't think I would use anything solid. I would go with expanded metal or similar so engine can breath. I think there is a thread with pics on here.
/ grille guard #4
I would think that, so long as you don't have the insert right up against the radiator fins, the air will still move through the radiator just fine. A tractor doesn't move fast enough to rely on air moving into the radiator, it just depends on the fan.
/ grille guard #5
I went with the expanded metal;after I speared my battery and lower grill.I prefer this over a solid piece of metal.
If you go with the metal;drill a bunch of small holes for a little better flow.
/ grille guard #6
What is the thickness of your expanded metal and is it 1/2" or larger expanded metal?
JOHN DEERE 8360R TRACTOR (A64278)
JOHN DEERE 8360R...
46190SFL (A64557)
46190SFL (A64557)
2014 Chevrolet Express Shuttle Bus (A64556)
2014 Chevrolet...
2025 58in Padfoot Vibratory Roller Skid Steer Attachment (A64553)
2025 58in Padfoot...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2019 GMC SAVANNAH 3500 14' BOX TRUCK (A65054)
2019 GMC SAVANNAH...
