grille guard
/ grille guard #1
hd5
Missouri
MF2705, MF135 XR4046H
I have a piece of shiny aluminum diamond plate. I think it would make a good insert for the grille guard, but concerned it might cut down on air flow.
I need to get something in there before I run a limb thru my grille.
/ grille guard #2
I don't have an insert in mine yet. I don't think I would use anything solid. I would go with expanded metal or similar so engine can breath. I think there is a thread with pics on here.
/ grille guard #4
I would think that, so long as you don't have the insert right up against the radiator fins, the air will still move through the radiator just fine. A tractor doesn't move fast enough to rely on air moving into the radiator, it just depends on the fan.
/ grille guard #5
I went with the expanded metal;after I speared my battery and lower grill.I prefer this over a solid piece of metal.
If you go with the metal;drill a bunch of small holes for a little better flow.
/ grille guard #6
What is the thickness of your expanded metal and is it 1/2" or larger expanded metal?
2021 CATERPILLAR 302.7D CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65053)
2021 CATERPILLAR...
3148 (A63117)
3148 (A63117)
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
