Greetings from TX
/ Greetings from TX #1
Snowback
Platinum Member
Houston TX
Mahindra 2538
Howdy,
Just joined today. Amazing how many new folks are joining. I have been lurking for a while and have learned quite a bit. Thanks everyone!
Proud owner of a Mahindra Max 25 with FEL, 4' Box Blade and 4' Brush Cutter. Use it to maintain 2 acres and play around our community that always has something to do for a tractor.
Some guys get fast cars for their mid life crisis - I chose to pre-empt the crisis with a tractor. It's therapeutic I believe. :cool:
/ Greetings from TX #3
Snowback
Welcome!!! This place can be a lot more than therapeutic. Welcome aboard.
Charlie
/ Greetings from TX #10
A tractor in Houston would almost make it tolerable if I had to work there. :D
Welcome.
/ Greetings from TX #11
Welcome.... I get out of Houston every chance I get..
/ Greetings from TX #12
Welcome to TBN from Missouri.:)
/ Greetings from TX #13
welcome aboard....getting out of Houston is a fine goal. Don -- do ya think ya coulda got a tractor up your condo? ....maybe in the lobby?:laughing:
/ Greetings from TX #14
We were in the process of cleaning Herman Park up until a sierra type group shut us down. The underbrush let the attackers hide and we were trying to cut down on the assaults.
Wow! it's good to be in central Texas!:thumbsup:
/ Greetings from TX #15
Great to have you aboard. Welcome, I hope you enjoy your stay at this wonderful forum. :thumbsup:
Chad
/ Greetings from TX
Thanks for the welcome everyone!
We're actually in Conroe up North, but it's basically all Houston as far as the eye can see. Trying to post a few pics here - hope it works. This Max 25 is a beast and has been a real joy so far. Right at 30 hrs with 200+ yards of dirt moved/spread and about 30 acres cut. Also some plain 'ol fun moving things around. Easy to cut tall swamp grass and weeds at low RPM as well.
The last pic shows the width of the machine as it relates to the 50" bucket and 4' box blade which is wide enough to perfectly grade out tire tracks even in loose dirt. Really nice match up all the way around.
2015 FREIGHTLINER M2 106 T/A 6X4 FLATBED WITH MOFFET (A59909)
2015 FREIGHTLINER...
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A61568)
2020 Broyhill Load...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
