Greasing suggestion needed
/ Greasing suggestion needed #1
rthrbhntg
Delaware Co NY
Kubota MX5100
Any advise on after how many hours to grease the pto shaft and best methods for a mx5100?
/ Greasing suggestion needed #2
i grease my mowers after every use.. that includes the telescoping frive shafts and joints and yokes.. pushes dirt out.. good lub for a high stress area..
/ Greasing suggestion needed #3
My Woods RD7200 mower suggest 25 hours. I adhere to that.
/ Greasing suggestion needed #4
I grease about every 10 hours of mowing use, Which where I live is only 2 or 3 times a year at most. When I mowed 7 acres at another location, I greased every mowing session.
James K0UA
/ Greasing suggestion needed #5
Were you referring to the PTO stub on the back of the tractor? If so, a cleaning to get the grit off and a very light coat of grease once in a while is enough. You don't want gobs of grease hanging off and attracting dirt. I use the rubber cover it came with most of the time to keep it clean when I'm not using the PTO.
Sean
/ Greasing suggestion needed #6
Sean
Ditto that
Charlie
Mini Skid Steer Pallet Forks (A64047)
Mini Skid Steer...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
Electric Tricycle (A64194)
Electric Tricycle...
Fair Oaks 12'  Multigrader Blade (A64047)
Fair Oaks 12'...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
2014 STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
2014 STARCRAFT...
