grapple teeth question
/ grapple teeth question #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
/ grapple teeth question #3
I'm doing a similar project for my FEL, it has a plain blade bucket.
Those tooth shanks say that they are cast. I'm not a welding expert, but I thought castings can't be welded with a normal MIG or stick type welding process. How would you attach the tooth shanks to the tooth bar? I have a Hobart 187 mig.
/ grapple teeth question #4
cast steel can be welded, so can cast iron - it just works better if you preheat and stress relieve after on the cast iron.
On the 175 vs 162 argument - the 162 will be more heavy duty at 1.5" wide rather than 1" wide, and the shorter, thicker mounting bracket will likely be sturdier overall, but I doubt you'll be putting enough stress on them to notice a structural difference.
On the other hand - there's only $5 difference in price, so a 7 tooth bar (6'?) would save you $35 going with the 175 tooth over the other. Is peace of mind worth the $35 or is your budget that tight?
Price wasn't the issue. I thought the longer more narrow shaft might help with popping up brush. Guess the stronger one would be the safest bet though.
/ grapple teeth question #6
I wouldnt use cast iron or cast steel for a tooth bar. You need forged steel to be strong enough to stand up to the abuse and to weld to a grader blade. The grader blades are normally hardened or armor steel which in itself is hard to weld together and requires lots of preheat to keep the weld from cracking and a 80K tensile rod or better to hold it together. Check ebay, there is usually a dealer selling toothbars for around $200 for a 60" which may be as cheap as you can build it. I found mine on ebal last year for less than $200 including shipping. I think the guy was in the midwest that had the cheapest price.
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A67147)
1997 KENWORTH T300...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
2020 Bobcat S450 Compact Wheel Loader Skid Steer (A64553)
2020 Bobcat S450...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
