Looking to those that have and or used grapples on their tractors. Looking for information as to use, limitation etc. Maybe how you would modify what you have for better use.
From what I can tell they look to be in about three main categories. What seems most often called a root/brush grapple that is flatter in profile with ripper teeth, and one that seems to have many names that is more like a bucket in profile that the upper and lower jaws are somewhat ell shaped. and the other is a ad-on bucket grapple.
The flatter profile would seem to give a higher lift when say loading on to a truck or trailer in that the lower jaw wouldn't hang down as much giving a little more clearance (?). Also thinking that if it was shorter on the fixed jaw you would retain lifting power which there is not a lot to spare on a compact to begin with.
I'm looking for something to handle brush, logs, roots, rock and pieces of broken concrete. And anything else that one would use one for.
Something in the 48" - 54" and 200-250 pound range.
Thanks in advance for any advice and experience.
