Grader blade guage wheels again
   / Grader blade guage wheels again #21
My first post but a long time fan of this site. I have got alot of ideas here so heres my guage wheels hope the pics are attached. I wanted large tires for better flotation on soft soil so I used golf cart tires. This was an easy build the hard part was the wheel hubs I couldnt find what I wanted so I modified a bought hub.
   / Grader blade guage wheels again #22
Kb73,
Have you got it dirty yet? Looks great!
David from jax
   / Grader blade guage wheels again #23
That looks beautiful, but if it is not a lawn ornement you need to scratch the paint and get it dirty!!:D
the only thing that I would caution you about is the pivot for the wheels and the frame for the wheels is a little light maybe. I know that I bent mine and had to go in and straighten everything back out. It looks absolutely great. You can post a new thread about your creation.
Mike
   / Grader blade guage wheels again #24
Kb, those look great!
Yeah, I would post a new thread on that beauty. Golf cart wheels are a good idea! I have a couple sets for my golf cart.
   / Grader blade guage wheels again #25
Its all dirty now my builds only look that nice once. A used tool is a happy tool. the pivot and hubs are the weak link but after use I think the pivot will be ok the main hoop is 21/2 x 1/2 material with a 1" solid spindle welded with a root pass and two cover passes I also taped in grease zerks on everything to keep them spining. If I get into more rough grading the wheels are on receiver tubes and can be removed. My driveway is 800 ft of gravel and thats its main use but i tried it in some pretty soft stuff and the wheels hold it right where I want it. The frt hub off a 3 wheel golf cart would be ideal but wouldn't you know when you try to find those things you can't but when I bought my 4 wheel golf cart all i could find was 3 wheelers.
   / Grader blade guage wheels again #26
kb73,
Oh, by the way, welcome to TBN kb73 (as a posting member)!!
David from jax
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
2421 (A60432)
2421 (A60432)
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
