Grade 70 or 43
/ Grade 70 or 43 #11
The working load limit of Grade 43, 3/8" chain is 5400 lbs. The working load limit of Grade 70, 5/16" chain is 4700 lbs.
Grade 43 Chain Specs.
Grade 70 Chain Specs.
I stand corrected. I'd remembered them being closer than that and should have checked..
I might add, 5/16 43 is 3900 lbs so it appears 5/16 grade 70 will put you right between grade 43 5/16 and grade 43 3/8" and at 2/3'rds the weight of 3/8's. I'll all for it! :)
/ Grade 70 or 43 #12
I understood what you were getting at, no it wont substitute the 5400# rating of 3/8 G43, but if you needed 4700# or less rating then you wouldn't have to go up to 3/8 from 5/16 you could just go with the G70 5/16.
4700# rated chain on 4 corners of a tractor would be more than enough for any CUT, but most go for the 3/8, myself included.
It is heavy, not the individual pcs, but I put my four 7 footers and 4 binders in a pail for storage, all fit nicely, just couldn't lift it without hurting something :( so I divided them into 2 pails and they are still heavy.
You mean like this nice golden finish? :)
I needed a short piece of logging chain so I bought the unplated grade 43 and plated it at work. This is better then any plating you will get of the shelf. It is a zinc-nickel alloy (87/13) with chromate topcoat finish. We use it on aircraft bearings.
QUOTE]
Sweet :cool: how's it done? with electro or hot dip? I'd be tempted to do all my unplated tools with the stuff, like shovels and rakes and what not :)
JB.
2020 DRAGON ESP...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1992 AM General...
