Grade 70 or 43
/ Grade 70 or 43 #1
bjess8
SOUTH CENTERAL ,PA
GRAND L3130
What is the difference between Grade 70 chain and 43?can you use grade 43 for hauling?thanks
/ Grade 70 or 43 #2
As far as I know you can use the 43 or unmarked chain. You will have to work within the limits or about one size larger than a grade 70. Look at the DOT site for your state or the federal motor carrier regs.
/ Grade 70 or 43 #4
grade refers to the hard/tough-ness of the chain.
much like bolts where a grade 8 is tougher and harder to break than a grade 3.
/ Grade 70 or 43
ok thanks I just seen some grade 43 in the nothern tool book and was going to get some for hauling my Grand L 3130 and just wanted to make sure it was legal.Thanks
/ Grade 70 or 43 #6
3/8 grade 43 chain is rated at 5400# and grade 70 is 6600# not a huge difference but not a huge difference in price.
Plus the grade 70 chain has that beautiful goldish chromate finish, not only looks good but is highly corrosion resistant.
I would get the G70.
JB
/ Grade 70 or 43 #7
And the best thing about grade 70 is, you can generally go down one size in your chain. That makes it lighter! Hefting chains around gets old.. :)
And it's more resistant to rust!
/ Grade 70 or 43 #8
JB
You mean like this nice golden finish? :)
I needed a short piece of logging chain so I bought the unplated grade 43 and plated it at work. This is better then any plating you will get of the shelf. It is a zinc-nickel alloy (87/13) with chromate topcoat finish. We use it on aircraft bearings.
/ Grade 70 or 43 #10
Your original question asked if you could use grade 43 for hauling. The answer was yes but I also agree that for the minimal difference in price get the grade 70 chain. Mike posted the specs for each.
/ Grade 70 or 43 #11
The working load limit of Grade 43, 3/8" chain is 5400 lbs. The working load limit of Grade 70, 5/16" chain is 4700 lbs.
Grade 43 Chain Specs.
Grade 70 Chain Specs.
I stand corrected. I'd remembered them being closer than that and should have checked..
I might add, 5/16 43 is 3900 lbs so it appears 5/16 grade 70 will put you right between grade 43 5/16 and grade 43 3/8" and at 2/3'rds the weight of 3/8's. I'll all for it! :)
/ Grade 70 or 43 #12
I understood what you were getting at, no it wont substitute the 5400# rating of 3/8 G43, but if you needed 4700# or less rating then you wouldn't have to go up to 3/8 from 5/16 you could just go with the G70 5/16.
4700# rated chain on 4 corners of a tractor would be more than enough for any CUT, but most go for the 3/8, myself included.
It is heavy, not the individual pcs, but I put my four 7 footers and 4 binders in a pail for storage, all fit nicely, just couldn't lift it without hurting something :( so I divided them into 2 pails and they are still heavy.
QUOTE]
Sweet :cool: how's it done? with electro or hot dip? I'd be tempted to do all my unplated tools with the stuff, like shovels and rakes and what not :)
JB.
2006 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2006 Montone...
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
Kubota M125X (A60462)
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
