GPM required to run mini-ex mulcher?
   / GPM required to run mini-ex mulcher? #21
MIke - the Tak 280 specs show two hard lines on the stick - the primary at 39GPM and secondary at 15 GPM so should be fine running a mulching head on the primary.
   / GPM required to run mini-ex mulcher? #22
My 260 runs a hammer flail pretty darn good.
So the Tak 280 has a weld patch on the lower dipper. I’m not too fond of those. Seller says he would take 25K….
Looking at a Wacker Neuson 8003-2, 18,000lb machine today.
   / GPM required to run mini-ex mulcher? #24
I have 3 primary needs:
Digging rocks out of fields.
Clearing fence lines and field edges.
Loading cut logs into truck.
I think this will make my life a lot easier, but then there’s that old pesky problem of parting with the money. This has been on my “list” for 5 years.
Don't forget transportation. I suspect you drive your tractor to most jobs? If you are set up for trailering then you are all set, but it's not practical to track an excavator very far.
I have a 38,500lb GVWR trailer.
Also have air brake dump truck to haul it.
I’m good.
   / GPM required to run mini-ex mulcher? #26
FRONT MOUNT POLY TANK W/ MOUNT (A52708)
FRONT MOUNT POLY...
2019 Chevrolet Tahoe SUV (A55973)
2019 Chevrolet...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
(4) 275/60R20 TIRES (A58374)
(4) 275/60R20...
2001 DODGE RAM 3500 (A58214)
2001 DODGE RAM...
