GPM required to run mini-ex mulcher?
   / GPM required to run mini-ex mulcher? #21
MIke - the Tak 280 specs show two hard lines on the stick - the primary at 39GPM and secondary at 15 GPM so should be fine running a mulching head on the primary.
   / GPM required to run mini-ex mulcher? #22
My 260 runs a hammer flail pretty darn good.
So the Tak 280 has a weld patch on the lower dipper. I’m not too fond of those. Seller says he would take 25K….
Looking at a Wacker Neuson 8003-2, 18,000lb machine today.
   / GPM required to run mini-ex mulcher? #24
I have 3 primary needs:
Digging rocks out of fields.
Clearing fence lines and field edges.
Loading cut logs into truck.
I think this will make my life a lot easier, but then there’s that old pesky problem of parting with the money. This has been on my “list” for 5 years.
Don't forget transportation. I suspect you drive your tractor to most jobs? If you are set up for trailering then you are all set, but it's not practical to track an excavator very far.
I have a 38,500lb GVWR trailer.
Also have air brake dump truck to haul it.
I’m good.
   / GPM required to run mini-ex mulcher? #26
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A60429)
2014 CATERPILLAR...
John Deere Z997R (A60462)
John Deere Z997R...
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
Broom Attachment (A59228)
Broom Attachment...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
