Hay Dude
Epic Contributor
- Joined
- Aug 28, 2012
- Messages
- 25,564
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
You’ve got two sets of auxiliary hydraulics plumbed to your stick. Primary which is always the higher flow set will run any attachments with high flow requirements such as a drum mulcher. Secondary set will run lower flow requirement attachments like the thumb or a rotator.
That 39 gpm primary output spec in your spec sheet is wrong I’m quite certain. It’s very close to the total flow of both auxiliary’s.added together.
Pretty embarrassing that the actual manufacturer of the Takeuchi mini ex published incorrect specs for their own machine.
