GPM required to run mini-ex mulcher?
   / GPM required to run mini-ex mulcher? #21
MIke - the Tak 280 specs show two hard lines on the stick - the primary at 39GPM and secondary at 15 GPM so should be fine running a mulching head on the primary.
   / GPM required to run mini-ex mulcher? #22
My 260 runs a hammer flail pretty darn good.
So the Tak 280 has a weld patch on the lower dipper. I’m not too fond of those. Seller says he would take 25K….
Looking at a Wacker Neuson 8003-2, 18,000lb machine today.
   / GPM required to run mini-ex mulcher? #24
I have 3 primary needs:
Digging rocks out of fields.
Clearing fence lines and field edges.
Loading cut logs into truck.
I think this will make my life a lot easier, but then there’s that old pesky problem of parting with the money. This has been on my “list” for 5 years.
Don't forget transportation. I suspect you drive your tractor to most jobs? If you are set up for trailering then you are all set, but it's not practical to track an excavator very far.
I have a 38,500lb GVWR trailer.
Also have air brake dump truck to haul it.
I’m good.
   / GPM required to run mini-ex mulcher? #26
FORKLIFT (A56857)
FORKLIFT (A56857)
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2017 Ford F-550 DurALift Bucket Truck (A60460)
2017 Ford F-550...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
Service Truck (A59230)
