Snow Attachments Got me a SNOW PLOW!!!
/ Got me a SNOW PLOW!!! #21
I dont know anything about snowplows, but please tell me all those fuel cans are empty, and the full ones are in a seperate fuel shed.
/ Got me a SNOW PLOW!!! #22
Those are very nice setups!! I plan to move to snow country next year so I will need a plow.I see some threads with front mounted blowers. What would be the preferred method, plow or blower??Considering if cost was not a factor...
jimmysisson said:
Kevin, how does your (beautiful) new plow float as the driveway dips and crests? It looks like it's held rigid hydraulically by the curl cylinders. Maybe there's some compliance in there I can't see in pic 1. My cobbed up Fisher plow hangs on a chain so it can rise and fall with uneven grade. Raising or lowering the loader alters the angle of attack - the ground contact is the shoes until you raise the loader quite a bit. I have a gravel drive, and the cutting edge is probably 1ス" off the drive with the plow frame level.
This year I welded much larger shoes over the old 4"x4" ones, now about 8" square, turned up a little at the corners. Last year it was warm and the drive didn't freeze even after it snowed, shoes dug it up. Yesterday's was much better, frozen drive and bigger shoes.
That setup of yours should push anything you get with no trouble. And yep, nice shop!
Jim
Jimmy,
Not sure how it will float over the dips. I have it adjusted to roughly 2-2.5 inches off the drive. I was thinking that putting the loader in "float" would allow the plow to follow the terrain. I have no flat land so it will be interesting to see how this works. I may have to fabricate some bigger shoes. Thanks for the advise.
keving
About half are full. I can't seem to keep them full! I realize that this is a substantial amount of fuel. I'm looking at external diesel fuel storage for about 200 gallons. As for the gas, do you recommend a better fuel storage system? I don't want to burn down my building! :eek:
/ Got me a SNOW PLOW!!! #25
I dont know with the cold weather. Down here I recommend a small cheap storage shed,lean 2 , or just cover them with a tarp. just do it away from the building.
/ Got me a SNOW PLOW!!! #26
I'm with Firemanpat on this one. I keep all of my cans in a cheap 8x8 shed, along with other combustables like propane tanks. I figure, if it ever goes, it's going to be one big boom.
/ Got me a SNOW PLOW!!! #27
If you don't have close neighbors...a couple of pallets to stack your stuff on and a tarp to throw over the top works as well...:D
/ Got me a SNOW PLOW!!! #28
streamin,
If cost is no object, both, A plow on the front and a pto snow blower on the back. The plow is much faster, and only problematic if you have small confines and nowhere to plow the snow.
The Curtis setup new runs in the $2500 area, (if you already have the hydraulics set up so you have a third function: lift, curl and angle)
If you have a blower only, you have more options to direct the removal location, but they are considerably slower when clearing large areas.
/ Got me a SNOW PLOW!!! #29
I plow with a 96" HLA (Horst) blade which is very similar to the Curtis.
Here in Maine I don't have to worry about plowing the sod up as it is nicely frozen. But regarding dips and contours of the land, you do have to kind of feather the joy stick. I curl up a bit when I'm going from driveway to grass. This allows the blade to keep plowing while not digging in to the grass.
When you hit an unexpected obstruction the whole blade trips forward (as opposed to just the cutting edge).
Tractor plowing, as compared to pickup truck plowing, allows you to lift the blade way higher and move snow banks WAY back. The only instance where a big snow blower is better, IMO, is for really long driveways with limited room for snow banks.
~Paul
PS - just got 12" of snow in my neck of the woods. Thankfully the ground WAS frozen, so I was able to plow my wood yard, etc.
/ Got me a SNOW PLOW!!! #30
My snowplow that I use is a fisher 7'6". I ran the hydo. lines from the back so I could angle the blade. Welded it onto a universal frame so I can change back and forth with my bucket.
15" of snow yesterday and last night here.
/ Got me a SNOW PLOW!!! #32
Then get a little metal building like those you see in trailer parks.
Set it at least 30 feet away from any other structures and put all flammable liquids in there along with push mowers chain saws string trimmers etx..
better to have them all go with the little building than to lose the house garage pole building right along with them cause you were keeping them in there instead of a little separate building.
__________________
/ Got me a SNOW PLOW!!! #33
Can you push and grade dirt gravel sand and slag as well as plow snow with a blower?
/ Got me a SNOW PLOW!!! #34
vic4news said:
Thanks for the tip. I usually have to put sand down a couple times because the snow on the gravel driveway freezes and ices up. It would be nice to use my new rake to bring up the stone so that I don't have to shovel sand.
Vic
How do you get sand that's not froze solid like a rock in the winter time?
/ Got me a SNOW PLOW!!! #36
keving said:
I bought a slightly used snow plow for my 7040 today. It's a 7.5 foot Curtis and I paid $2K.
* I am certain that it will not snow now in both West Virginia and Virginia.
*Hasn't worked for me.
I bought a 60'' Hyd lift and angle front blade last month and figured that would prevent it from snowing but we're getting snow as I type this.
Could accumilate up to 4 inches.
== L B ==
/ Got me a SNOW PLOW!!! #37
Sadly, a new record, 6 posts in a row. :confused: MrBrown you hit your 6000 posts now can you give the rest of us a break. :mad:
/ Got me a SNOW PLOW!!! #39
Yeah :Not a pretty sight from a safety stand point!!
Yep get em out of that garage.
/ Got me a SNOW PLOW!!! #40
Why are you talking to yourself Brown???
